Homemade Clay Refrigerator - BEING ECOFRIENDLY !
Intro: Homemade Clay Refrigerator - BEING ECOFRIENDLY !
Hi, I am Sahas Chitlange , aging 14 , from India . Here's my new innovation on fridge from clay. Its very easy and cheap to build and very cheap. In india the cost is about Rs. 300 only. The project's principle is based on evaporation. you can take this system for camping where you need a fridge to keep your cokes cool. The materials required for making this easy fridge are:
1) Clay pots
2) some sand
3) water
For the first time to get the cooling effect you need to wait for 10-12 hrs. The thing you need to remember is adding water after a day.
Snapchat and Instagram: @chitlangesahas
I'd love to connect with you guys on Snapchat and Instagram, I document the experience, learning lessons and also answer questions on those platforms. Looking forward to connect! Here is my username for both: @chitlangesahas
STEP 1: Chose Correct Pots
STEP 2: Adding Sand
STEP 3: Insert the Smaller Pot
Also see that you have some gap left on the sides , you need to add sand there later.
51 Comments
charan.surasani93 3 years ago
vincent7520 10 years ago
This is the basic cooling system by evaporation? And let me tell you, it works great !
The same idea has been use by putting large jars full of water in egyptian house where the could pass a stream of air that was cooled by passing between the jars and the refreshed ai cooled the house. The technique worked for centuries in Egypt and other countries in the region …
In rural France (before the 40's I saw many butter jars that prevented butter from melting by covering the butter pot with a cover that that was designed to contain water that could evaporate.
You certainly will not get a chilling effect … but it will keep food and dairy stables at a reasonable temperature under strong heat.
The basic ot what on may call "pottery refrigeration" is to use non varnished pottery for you can soak the part you want to be evaporated first in the water (ie cover) Ideally no varnished pottery should be used at all because … the higher the evaporation rate the more efficient the system will be
JadeC1 6 years ago
rodolfo.masiero 7 years ago
Ben fatto!
andriajithu 8 years ago
Good idea... can try it at home.... Thank you...
jacobpv 10 years ago
CarlaBurke 8 years ago
That depends on the sizes of the jars, how cold the water was, when you dampened it, the ambient temperature, and the relative humidity. So, it would be difficult to give an accurate answer.
Cambenora 8 years ago
Cool instructable (if you'll pardon the pun...)
In Australia in the 19th century there was a thing called a Coolgardie safe:
(https://en.wikipedia.org/wiki/Coolgardie_safe)
which was a refrigerator which used water evaporation as its cooling mechanism much in the same way as you have here. A different design, but the same principal.
Good work.
TrevorS3 9 years ago
So this stays outside? Should it be in the shade or out in the sun? If it is in sun then it will evaporate faster and cool better but will also need more evaporation to compensate for greater heat... I live in a smallish trailer and don't want to use propane to keep food cool and don't have it in the budget for a large solar panel.
I will try and rig up a drip irrigation emitter to drip over bowl part into sand and either use timer or get very low flow emitter and drill an overflow opening towards top.
Saakaar Barthwal 9 years ago
wowwww cool it is just like mitticool
burnettis.1 9 years ago
very nice and more power to you for sharing your knowledge.
I live in Morocco, so it is good news for poor people and those with out electricity.
I will share your generous work.
snoopindaweb 9 years ago
cOOl.! ~( : - } )=>=== ] Favorited. The vote don't seem to work.
Chitlange Sahas 9 years ago
Thanks.
aebe 10 years ago
neelakantam aravindraj 10 years ago
i am from india......
jsolterbeck 10 years ago
tekaka 10 years ago
rkrishnan7 10 years ago
gn0stik 10 years ago
rimar2000 10 years ago
