Hot Glue Caulking Tube Saver
Intro: Hot Glue Caulking Tube Saver
This idea came to me when I was putting trim on and refinishing my mom's staircase and was caulking the corners.I only used half a tube and didn't want to waste the rest. Earlier that day I was at the thrift store and found a beefy hot glue gun for a couple bucks. So I thought of using it to seal up the end of the tube.
If you feel it's worthy vote and favorite.
Thanks for reading.
STEP 1: Materials
Materials are pretty simple.
- Hot glue gun with glue stick
- Opened caulking tube.
That's it.
STEP 2: Gluing Up
Just plug in the hot glue gun and wait for it to heat up.
Put a generous dab on the end of the caulking tube to cover the open hole.
STEP 3: Finished
Let it solidify and you're good to go.
It should pop right off when you're ready to use it again.
Thought it would make a perfect entry for the Glue Contest.
Favorite and vote if you feel it's worthy.
https://www.instructables.com/contest/glue2014/
Thanks for reading.
14 Comments
Ehlers_TV 8 years ago
...I always put a screw purely .... but good idea.
Ultra-Indigo 8 years ago
pfred2 9 years ago
When you tube of caulk goes bad, and it will, you can use it as a sanding belt cleaner then.
LoMac 9 years ago
That's a great Idea! I have a dried one laying around. I'll have to cut it open and give it a try. Thanks for the tip.
pfred2 9 years ago
Abyssion37 9 years ago
sleepyhhead 9 years ago
aaahotdog 9 years ago
Depends. Silicone type probably, latex seems to be the one that dries up. But you can use this tip on other things than just caulk.
Not to bust your bubble
https://www.instructables.com/id/What-to-do-with-op...
Thanks for repeating it though.
LoMac 9 years ago
Don't worry my bubble is intact. I always find it interesting when people come to the same conclusion when solving a problem. Maybe we are sole mates. Have you tried it without cleaning it out first? I've only used the hot glue technique once before.
I've cleaned it out. It makes a nice little plug and is pretty air tight. Caulk is just like it came out of the store yet. I guess great minds thinks alike :)
dushyantahuja 9 years ago
Simple and elegant - never thought of this
TheLacedAngel 9 years ago
Wow, so simple, and so smart!
Danger is my middle name 9 years ago
This is a great life hack!
