Hot Knife for Plastic Cutting!
Intro: Hot Knife for Plastic Cutting!
Probably, the EASIEST Instructable you'll ever see to make the most useful tool a DIYer could ever wish for! Sometimes "simple" is the answer....
STEP 1: Get a New Soldering Tip!
Then take a hammer to the end of it until it's nice and flat.
STEP 2: Screw It!
Back on your soldering iron!
STEP 3: Cut Stuff!
Works amazingly well on any kind and thickness of plastic. Makes custom modding and DIYs a breeze. The best part is, you can switch back to your soldering tip when you're done cutting! 8D
Wasn't that easy? If you want to, feel free to check out the video that shows how much crap I went through to get to this solution...lol! Watching this helps me keep coming up with these ideas... a blatant attempt to promote a video I admit ;)
But it's a pretty amusing example of how hard it can be to come up with a simple solution...
23 Comments
InnocentM12 6 years ago
I don't Usually comment on these posts which i think is mean but i had to comment on this Just to say thank you. After fighting hard with a hot knife and spending hours cuting simple plastics, now i have a better solution.
OwenD1 9 years ago
You could also just heat an old paring knife with a torch.
huttarl 7 years ago
Have you tried that? I tried with a utility knife, and it didn't cut very far. I think the blade cools down too quickly, which is why you need a soldering iron.
exabopper 13 years ago
shannonlove 11 years ago
And that's about all the metallurgy I remember from college.
Nickson Yap 11 years ago
It should be pretty soft...
guitar-is-awesome 13 years ago
xeniczone 13 years ago
This is ideal for places that a Dermel can't reach or can't cut precisely otherwise you should be using a Dremel.
anthonyyy0 13 years ago
mman1506 13 years ago
AZombieHippie 13 years ago
woodvale035 14 years ago
it does stink a bit tho..
thoraxe 16 years ago
trf 15 years ago
BigNateMI 16 years ago
!Andrew_Modder! 16 years ago
pyro13 15 years ago
Mr. Rig It 16 years ago
Check out my circle ible The circle
Hopefully it will give you even more ideas.
I will keep this one in mind.
babblin5 16 years ago
Spectrace 16 years ago
