How to Chop Your Head Off
Intro: How to Chop Your Head Off
This instructable is made for a prop only Do Not Use As The Real Thing can be dangerous. Ok now to build the best April fools ever.
What you will need
Tools
-driver
-drill press with a 1.5 inch drill bit
-pencil
-ruler
-band saw, table saw might work or miter saw
Materials
- a lot of wood I just used a ton of old scrap wood I will explane more of what you need later you can twek the build if you need to.
- metal pipe when we get to that step you can chose what you want to use
- some way to keep you metal blade on the wood will show you it on the step
and now to the Build.
What you will need
Tools
-driver
-pencil
-ruler
Materials
STEP 1: Building the Bottom Blade
on this step I will teach you how to build the bottom blade on your head chopper.
so you take a board about two feet long and use a drill press to create a big grove. Witch will become your guide for your blade. then take a pipe like you see in the photo and make sure it fits in the grove and insterst it and atach it down.
STEP 2: Building the Stand
Now that you have your blade in the wood you need to build the stand for this. I just used two 1 ft long bords to make the stand you can do as in pic below.
STEP 3: Building the Guide Rails for You Head Chopper
In this step you will build the guide for you head chopper. Just take two poles and screw a few bord and build guide rails as you see in the pic.
STEP 4: Building the Chopper
ok on this step you need to build the slicer I took a bord that fit inbetin the guide rails. and thats how to build a head chopper please comment on my Head chopper in the april fools chalgnge
you just put you head in it and make it look like you have chopped off you head with a ton of fake blood
Happy fooling
Pyromanic101
Happy fooling
Pyromanic101
2 Comments
mikeasaurus 12 years ago
What you've shown here is the frame of a guillotine, with no 'trick' on how it's a prank. Also, are these pictures yours? If so, you might want to go into more detail to explain what you are doing.
Leave me a note here when you've taken another look over your project and I'll see if we can publish/enter into the April Fools Challenge.
pyromanic 12 years ago
