How to Manually Merge Gmail Account With Apple Mail 2.0-3.x
Intro: How to Manually Merge Gmail Account With Apple Mail 2.0-3.x
This tutorial will instruct those with basic computer skills how to merge their Gmail account into Apple Mail 2.0-3.x in 10-15 minutes.
YOU WILL NEED:
-an Apple computer with Apple Mail 2.0-3.x
-an Internet connection.
-an existing Gmail account.
HOW TO CHECK IF YOU HAVE THE CORRECT VERSION OF APPLE MAIL (2.0):
1. Open the APPLE MAIL APPLICATION.
-The mail icon will be on your desktop. This looks like a postage stamp with an eagle on it.
-If you cannot find Apple Mail, search for the application using the magnifying glass on the top right corner.
2. Click MAIL on top left of the computer screen.
-A drop down menu will appear.
3. Select ABOUT MAIL from the drop down menu.
4. A pop up screen should come up stating what version of Apple Mail you have.
5. If you have Apple Mail 2.0or any Apple Mail 3.X , then you can manually follow this tutorial.
6. Exit out of all windows.
YOU WILL NEED:
STEP 1:
Open your desired your Internet Browser (Safari, FireFox, Google Chrome, etc).
STEP 2:
Go to www.gmail.com and sign into your account.
STEP 3:
Click the GEAR IMAGE on the TOP RIGHT CORNER of the website.
- A drop down box of options will appear.
-Click MAIL SETTINGS.
STEP 4:
Click the tab Forwarding and POP/IMAP.
STEP 5:
Click the bubble ENABLE POP FOR ALL MAIL.
STEP 6:
Click SAVE CHANGES at the bottom of the page.
STEP 7:
Exit out of the Internet Browser.
STEP 8:
Open the APPLE MAIL APPLICATION .
STEP 9:
Click Mail on the TOP LEFT CORNER of your screen.
-Click PREFERENCES.
-Click PREFERENCES.
STEP 10:
Click the tab Accounts.
-Click the PLUS SIGN [+] AT THE BOTTOM LEFT OF THE WINDOW to create an account.
STEP 11:
Enter all information correctly on the window titled “Add Account”:
a. Your Full Name.
b. Email Address: (the Gmail address you are linking)
c. Password: (for the Gmail account)
a. Your Full Name.
STEP 12:
UNCHECK AUTOMATICALLY SET UP ACCOUNT.
STEP 13:
Check all information is correct and click CONTINUE.
STEP 14: Incoming Mail Server
Enter and check all information:
a. Account type: POP.
b. Description: YOU DECIDE. EX: GMAIL ACCOUNT.
c. Incoming mail server: POP.GMAIL.COM
d. Username: ENTER GMAIL USERNAME.
* If your email address is: example@gmail.com then your user name would be: example.
e. Password: YOUR PASSWORD FOR THIS ACCOUNT.
STEP 15:
Click CONTINUE.
**If the “Incoming Mail Security” window appears, makes sure that “SSL” is checked, and the Authentication box is set to “Password.”** After, Click CONTINUE.**
STEP 16: Outgoing Mail Server
a. Description: LEAVE BLANK.
b. Outgoing Mail Server: SMTP.GMAIL.COM.
-Leave ‘USE ONLY THIS SERVER’ unchecked.
c. Check USE AUTHENTICATION.
- Username: ENTER GMAIL USERNAME.
*Email: example@gmail.com
*Username: EXAMPLE
d. Password: ENTER GMAIL PASSWORD FOR THIS ACCOUNT.
*Username: EXAMPLE
STEP 17:
Click CONTINUE.
**If the “Outgoing Mail Security” window appears, makes sure that “SSL” is checked, and the Authentication box is set to “Password.” ** After, Click CONTINUE**
STEP 18:
Check the "Account Summary" is correct:
a. Incoming Mail Server: POP.GMAIL.COM
*SSL: ON.
b. Outgoing mail server: SMTP.GMAIL.COM
*SSL: ON.
c. Check TAKE ACCOUNT ONLINE.
*SSL: ON.
*SSL: ON.
STEP 19:
Click CREATE. The account should now be set up.
STEP 20:
Exit out of ACCOUNTS and PREFERENCES windows and return to the APPLE MAIL APPLICATION.
STEP 21: How to Use Apple Mail
Click MAIL.
-Select PREFERENCES.
STEP 22:
Go to ACCOUNTS TAB.
STEP 23:
Select the ACCOUNT you just configured on the left side.
STEP 24:
Check ACCOUNT INFORMATION.
STEP 25:
Click ADVANCED TAB.
STEP 26:
Check PORT NUMBER:
-Port: 993.
-Port: 993.
STEP 27:
Make sure ‘USE SSL’ is checked.
STEP 28:
Close PREFERENCES WINDOW and return to the APPLE MAIL application.
STEP 29:
To RECEIVE MAIL:
-Click GET MAIL on the top left corner of the application.
STEP 30:
To SEND MAIL:
-Click NEW MESSAGE in the middle of the application.
STEP 31: To Add an Additional Gmail Account
Return to PREFERENCES.
STEP 32: To Add Another Account
Click ACCOUNT.
a. Click the PLUS SIGN (+) on the bottom left corner.
b. Repeat steps 11-28.
7 Comments
blogging313 12 years ago
N.Hitchcock
bmg3 12 years ago
Engl313UA 12 years ago
scheinma 12 years ago
KH2323 12 years ago
ksteven1 12 years ago
Otherwise, the instructions are very well written and easy to follow.
Great job!
randofo 12 years ago
