How to Curl Your Hair With a Flat Iron
Intro: How to Curl Your Hair With a Flat Iron
You don't need a curling iron to get perfect curls you’ll love! Next time you are looking for a new, fun hairstyle, pull out your flat iron and get these amazing results!
This hair style was done by Sharelle Loudd at Beautique Salon in San Jose, CA. She was awesome enough to demonstrate this secret flat iron curling technique while we documented the process. We hope these tips will help you make the most of your long natural hair without pulling out a curling iron and burning your forehead.
You may be tempted to buy one of those fancy new curling rods, but it's easier than you think to use a flat iron to curl your hair. Keep reading to find out how!
Thanks to audreyobscura for the beautiful photography.
STEP 1: Tools and Products Needed for Flat Iron Curls
Supplies:
- Flat Iron - any one should do, but we are using a 1 inch wide flat iron
- Kera Care Oil Sheen Spray
- Kenra Volume Spray - Something to hold the curl
These are the hair products we used to create the curls, but you can sub in similar products as well! You'll need a spray to hold the curls, and an oil-based spray to use before flat ironing your hair. This will add shine and protect your hair while it curls.
STEP 2: How to Comb Out and Pin Up Hair for Flat Iron Curls
Take a half inch section from the nape of her neck and spray with oil sheen. Oil sheen helps with the glide of the flat iron over the hair. Go ahead and smooth the oil sheen through the body of the hair.
Tips for Curling Hair:
- Wrap as if you were using a curling iron (don't close the flatiron completely).
- Use less heat for blonde hair and scale up as hair darkens.
- You can tell if you're putting enough heat in with the flatiron by feeling the hair. It should feel warm, which lets you know that the heat is reaching all of the hair.
- You can't put too much hair in at once, or it'll be too too tough.
- Don't do the tips of your hair until the end, as they require the least amount of heat to retain the curl.
Here is just the motion you will be using as you twirl you wrist to turn the flat. Check your pulse, twist, look at your watch, twist, repeat:
STEP 3: The Basics of the Flat Iron Curl
Take flatiron and use it underneath your hair. You will be twirling your wrist around while holding the hair with your other hand when making the turn. So you are turning the flat iron, not the hair around the flat iron.
As you can see in these gifs, you aren't wrapping all of your hair around the flat iron like you would with a curling iron. Instead you wrap just part of the hair and slowly and carefully pull it down the length of the hair.
STEP 4: Using the Flat Iron to Make Waves
This method is to get "Beach body wave curls," a looser curl that falls down your back.
So instead of pointing the tip of the flatiron down, point it up, angling up (the angles do the curls).
Keep hair centered in the flatiron to avoid snags. Once you have it all wound around the flat iron, carefully unwind. If the curl comes out too tight, you can run your fingers through it to loosen it up.
Unlike the other curl, you wrap all the hair around the flat iron and then carefully unwrap it.
STEP 5: How Your Flat Iron Curls Should Look
To finish off your new curly hairstyle, spritz with Kenra. You can also use an oil sheen and comb the top part of the hair to smooth it out.
28 Comments
SashaS43 6 years ago
I'm used Karmin's hair curler is excellent I left the curl super cute. I recommend it.
Katy Shee 6 years ago
I’ve always wanted to try this! But can you curl your hair with every brand of straighteners?
Penolopy Bulnick 6 years ago
Yes, you should be able to do this technique with any brand of straightener :)
indigo236 7 years ago
i loved the look of the curls i have natural ringlets but i love to experiment with hair styles
Penolopy Bulnick 7 years ago
Thanks and I agree, always fun to try new hairstyles :D
AnikaP1 7 years ago
All this is so well documented and that's great! I have poker straight hair but I crave for curls and more volume all the time. I also use flat iron to curl my hair but the difference is - I'm NOT able to do this good job. But it is also damaging my hair so I'm trying some more ways to curl my hair without heat which I read here http://thelifesquare.com/how-to-curl-your-hair-85...And I must say one of them worked for me really well.
RachaelM24 7 years ago
Cant wait to try this for the last day of school so excited
Yay! Love to see a picture if you get a chance :)
AnaR33 8 years ago
♥ Karmin makes the best in my opinion ^_^
Simran Sharma 8 years ago
I like it
AmiR11 8 years ago
Can you please show the motion with the hair inside the flat iron? I am THAT clueless....is there a good number of seconds inbetween flipping your wrist? Are you wrapping around the flat iron or through it?
BeBeautyAshley 9 years ago
Im Trying this with my Victorya flat iron from ISA Professional, the ceramic tourmaline plates should be perfect for this. Thanks for this!
shelbyE 9 years ago
i have tried it is so great if you are in a hurry for a b day part or wedding
AmandaKelly 9 years ago
Hi, nice advices! My Karmin works really well at straightening and curling hair.
sujistar 9 years ago
going
to
try for
sure:-)
poutbrush 10 years ago
Wow your hair is so beautiful! :)
Muhaiminah Faiz 10 years ago
The curls look soooo cute! I've never used flat iron for curling hair! I'll try :)
PitStoP 10 years ago
You have long beautiful red hair.. =)
Penolopy Bulnick 10 years ago
Tanks!
