How to Make Ethernet Cable Checker
Intro: How to Make Ethernet Cable Checker
My ADSL Modem is far away from my home so I use Ethernet cable to bring internet to my home...But sometimes internet is disconnected. I noticed that is is the fault of cable. So I made this small but very helpful gadget...Concept behind the project is very simple.... In Ethernet, connection is established through only 4 wires out of 8. (I will discuss Ethernet cable jack pinout in next steps)...So I checked only 4 wires...If these are OK cable is suitable for Broadband Internet. But If some LEDs are not ON or all of them are OFF then Cable is cracked/broken...
STEP 1: Part List
1). RJ-45 Socket x2
2). 1.5 Volt AA Battery x2
3). AA Battery Holder x1
4). Matrix Board x1
5). 3 volt LED x3
6). 3 volt small LED for Power Indication x1
You should also have wires and soldering experience and proper soldering tools (Soldering Wire, soldering iron, soldering rosin, etc.).
STEP 2: The Power Unit - One End
This is the power source for LEDs. I used RJ-45 Socket. And I used 2 AA batteries (1.5v*2 = 3 volts) to power 3 LEDs on the Second End on other side of wire.
STEP 3: LED Indicator Unit - Other End
On the other side of wire I made a small unit containing 3 LEDs to check the 4 wires of Ethernet cable. 3 LEDs are for 4 pins (3 pins are +ive, one for each LED While 1 pin in for -ive/ground, common for each LED).
Solder the 1,2,3 and 6 number pins of RJ-45 Socket to +ive and -ive terminals of LEDs respectively. That's All...
STEP 4: Ethernet Cable Pinout
STEP 5: Circuit Diagram
STEP 6: Checking the Cable
I have checked my 200 feet cable with my cable checker....
To check the long distance cable you have to do only a small effort, plug one end of cable on Power Unit and other end of cable on LED Indicating Unit.
If all 3 LEDs are ON, Your cable is Okay.
If any of these LED is OFF, Cable is broken or Connectors on the ends of cable are not connected to cables properly.
Hence you can diagnose any Ethernet cable on your own with the help of this small but very useful tool...
Please vote for this...Thanks..!!!
43 Comments
Zaeem Khan 8 years ago
very well... (y) Its might me helpful. I am also a student of Computer Science. I will make and test this one and I thought it will work as you described.
Sunny Yoshima Taru 8 years ago
Tahuna wa'ora ze nuf.
MujtabaAlAhmad 8 years ago
Thats Perfect small but very useful tool.
Babr Rohinz 8 years ago
Nice project....Do you tested this properly for Ethernet connection of every type connection ?
Tehseen-Hasan 8 years ago
It test it in my connection as I described above in description. And I sure this will work perfect for small scale connection network. work it can't be used in the connection having POV (Power Over Ethernet) so Do'nt use it there.
Ahsan Babu 8 years ago
Bohat aala jnaab.... Great Idea... (y) :-D
Syed Umair Shah 8 years ago
bohat acha ha yr...kesay bnaya.
Khan Baba 8 years ago
perfect work (y)
Shah AlHasan 8 years ago
هو أداة جيدة للغاية. أنا أحب ذلك لجعل. عمل جميل وإخوانه
شكرا سيدي
Robret Sohal 8 years ago
Nice job Tehseen. I will use this to check the connections in my Ethernet networking while making Films.
Urooj Rani 8 years ago
small but useful (y) ....Yeah nice thing
Zubair Ali Khan 8 years ago
Thats grate (y)
Anas Rehmani 8 years ago
Okay its funtastic small but useful tool. But can it be used for gegabite connection, etc. ?
Thanks. No It is only for megabites connection. because it uses only 4 wires out of 8.... But you can also make 8 wire checker similarly.
Rana Qamar 8 years ago
That's perfect Tehseen. I will sure make this. because I often need this type of gadgets. (y)
SpankyO 8 years ago
Nice work :) and Yes a Box would be great, and i was thinking.. even something as simple as a push button switch or toggle switch. between the power and the first plug.one for each line and you'll break the circuit so you can see if a wire is crossed ..?
Yeah its also a good point...Thanks!
helllordkb 8 years ago
Great instructable. but 1 WORD OF WARNING. this will only give you verification of continuity on all wires. It won't verify you have each RJ45 connector pin to the right color wire on each end. You still need to make sure you have all the right colors connected to the same pins on the RJ45 connector at both ends.
if some of your wires were connected too different pins on the RJ45 connector at one end vs the other, you'd still get a solid light.
It will work OK If we connect connector according to IEEE rules about RJ45 connector for Ethernet....
