How to Make a 13ft Tall Bookcase
Intro: How to Make a 13ft Tall Bookcase
In this build i create a 13ft tall bookshelf with a rolling ladder. I use mostly maple cabinet grade plywood and rough sawn soft maple for the face frame.
If you would like to attempt this project on your own, here are a few tools I recommend!
- Table Saw
- Tape Measure
- Impact Driver
- Drill
- Mitre Saw
- Jointer
- Graco Finish Pro HVLP
- Endurovar Finish
- 23g Pin Nailer
- Japanese Cut Off Saw
Thanks for checking out this build!
STEP 1: Breakdown Material
Begin by breaking down your plywood into the dimensions of your vertical boards. I cut mine into 11.25" strips from the large sheet, then down to final 11".
STEP 2: Glue Up Parts
Rough cut down all your shelving to size. Stack them neatly so you can stare at how much work you put into the neatness of the pile, then destroy it by gluing everything up. I use 1.25" 23g pin nails and tons of glue.
STEP 3: Layout and Cut Joinery. Assemble Carcass
Mark out all the locations for the shelves on your vertical partitions. Be sure to reference the correct faces so everything lines up. Use a jig, and drill perpendicular holes half way through the partitions. Cut the coordinating holes in all of the shelves.
STEP 4: Mill Stock for Face Frames
Rough cut your face frame material (rough sawn soft maple) and cut it into 1.5" strips. Start by jointing one face and a perpendicular side. Then cut your strips from the flat part as reference. This will leave the "rustic" top
STEP 5: Final Assembly and Finish
Glue the face frame onto the carcasses. Sand appropriately and finish with paint and a coat of water based poly. Then Install.
24 Comments
jgwinner 6 years ago
Fantastic!
It would be great seeing how it's attached to the wall and the floor. I'd also like to see how the splice works, as I'm assuming your longest vertical was shorter than 13 feet.
I have a 14 foot wall to put bookcases on, so this is an interesting project. I don't want the ladder to pull the books down :)
Love the comment about stacking the piles - some people see clutter, others see potential.
== John ==
John_Malecki 6 years ago
I have the fasteners hidden so they arent visible. I used metal L brackets and Concrete screws. The tops are sitting on dominos for alignment in the bottom. The top also has fasteners hidden behind it
jgwinner 5 years ago
Jane Ward 6 years ago
Fantastic, cannot wait for pay day. Thank you for this
DrKZ 6 years ago
Just wondering what the width of each shelving unit is, i.e. how many shelf-feet of books does this baby accommodate? You see, we DO have 13+-foot walls and need bookshelves. Also would like to know more about the ladder. Specifics, please, so we can make this, thanks!
Each shelf is 12" Deep and they vary in width. From 14" on the left to 22" on some I believe.
Here is a ladder link http://www.specialtydoors.com/obscure/
DrKZ 6 years ago
Jedi_zombie85 6 years ago
This is insane buddy, looks brilliant, hats off to you
Ya its big! Thank you
CatS25 6 years ago
Now on my to do list. Where did you find the ladder and what length did you go with?
Here is the link for the ladder
Its 9'
EdensGrandma 6 years ago
I have a very tall wall. Hmmmmmm. Thanks so much for this lovely bookcase demo.
You're welcome!
wetrat1 6 years ago
Great Instructable . Really would like more information on the ladder
BrandonS159 6 years ago
very nice, where did you get the rolling ladder or how did you build it?
zonkerharris 6 years ago
That's also my question! I'm guessing that he welded it, and maybe he can make an instructable for that?
I'm trying to think about similar shelving for maker supplies (12-18" deep, and sturdy), but how could I adapt a rolling ladder to I have a (pulley-type?) mechanism to raise and lower my supplies in front of a shelf, so I can climb the ladder, and then use one hand to move the materials tub from the wall shelf to the mechanism shelf?
I did not make the ladder. Its for a corporate space and I wasnt messing with that liability. Here is a linkhttp://www.specialtydoors.com/obscure/
As far as the pulley system You could use a rod and have it roll back and forth above the ladder.
Arandall86 6 years ago
