How to Make a Powerful Hydraulic Press
Intro: How to Make a Powerful Hydraulic Press
How to build a hydraulic press at home that can crush everything from metal cans to glass light bulbs. This quick DIY was a super fun project and great for science fairs or class projects on fluid and hydraulics. Check out the full video as well to see a quick assembly of the project
The Parts you will need are:
- 4 large syringes
- 1 small syringe
- 2 one-way valves
- plywood
- glass jar
The tools you will need are:
- Drill
- Gluegun
- hacksaw or reciprocating saw
- 2 part epoxy
STEP 1: Preparing the Base
To start off i get 4 pieces of plywood that i got from the dollar store. I stack 2 pieces on one another to make 2 thicker pieces of plywood. I then drill 5 holes on each side of the plywood. At this point i have 2 sheets of double thickness plywood with holes on both sides. One of these will be used to hold the syringes, the other will be put at the top of the press. The one used to hold the syringes will need to have slots cut out of it with a hacksaw or reciprocating saw.
STEP 2: Building the Base
Next we need to put 5 dowels through each side side of the plywood. After that we need to also drill 5 holes in a piece of plywood that will be used as the base. we can then mount the piece with the dowels though it in the base. before mounting you should also add the piece that will slide up and down the tracks. this piece should be drilled with larger holes so it slides freely.
STEP 3: Adding the Syringes
Next we can mount the double piece of plywood that belongs on the top. Secure all the pieces that are stationary with 2 part epoxy. After that we can mount the large syringes on the base. For the syringes be sure to use large ones because that gives us a mechanical advantage! Once all the syringes are mounted we can then mount the sliding piece to the syringe (it will probably disconnect when you start using so that’s not too important). I also mount some plywood to the bottom of the moving piece of plywood to strengthen it.
STEP 4: Making the Water Splitter
Now we need to create a mechanism to divide water from 1 tube up into 4 different directions. For this i get a little plastic cup and epoxy a piece of wood to the top of it. I then drill 5 holes in that piece of wood for all of the tubes we will be adding. I then put in a 1 way valve in the middle hole and 4 tubes in the other holes. Make sure to put the one way valve in so that water will be able to enter but not exit.
IMPORTANT: there will be alot of pressure in this , not a dangerous amount but enough to cause leaks. I originally had leaks so to fix this i covered this entire water dividing mechanism in epoxy. Its not the best solution but because the wood allows some liquid to travel through it , i found the best solution was to empty a whole tube of dollar store epoxy a piece of cardboard, mix it up and cover the water splitter entirely in epoxy Once that’s done we can attach the tubes to the large syringes
STEP 5: Making the Pump
To finish the project up we simply need to add our pump to it. To make our pump i simple mount a syringe on a piece of plywood. I then drill a hole into the syringe and mount another 1-way valve. This will let us draw water from the jar when we pull be when we are pushing the water will only be able to go into the press. The bottom end of the syringe should be connected to the 1 way valve on the press
STEP 6: Test
To test the project fill the jar up with water and start pumping. when crushing things be sure to wear safety goggles just in case anything shatters. to reset the press detach the tubes from the syringe and reset the syringe back to their original positions. To see all the things i crushed with mine check out the video .
For more content like this check out with website and youtube chanel !
22 Comments
The Ghost123 1 year ago
JFishy 2 years ago
misterxp 5 years ago
1041178 3 years ago
muhammadusmansarwar 5 years ago
67380 3 years ago
JamesA41 4 years ago
Davilyn2 4 years ago
trarnold 5 years ago
Some questions though, what are all the sizes of your materials?
Length x Width x Thickness of the plywood
Diameter of the dowels and of the plastic tubes
Also, what did you use for the cup at the top of the press?
I have several students who want to do this project but I need to know what to purchase!
By the way, I agree with "AndrewA167", safety is a big issue with me and I push that with my students all the time. Not to be mean but I used your video as a learning tool!!
It demonstrates some of the unacceptable safety practices you used and we turned that into a classroom discussion!
On a side note, I plan on making my students calculate the PSI that this press produces - that ought to be a fun addition!
Thanks and I look forward to your response!
agulesin 5 years ago
Joshbuilds 5 years ago
charlessenf-gm 5 years ago
ElectroFrank 5 years ago
signOnthe 5 years ago
Or make a hole with a plug or valve to drop out water manually into something on second tube.
jjmcgaffey 5 years ago
Did you consider using a jar with a screw lid for the water splitter, rather than wood and epoxy? A plastic or metal lid should hold at least as well, be drillable, and not be porous.
Looks like fun - and maybe useful, I make cheese and need to press some of it pretty hard. Though for that it does need to be even pressure (it looks like one syringe gets slightly less water than the others, in your video), and I'd need some way of measuring how much pressure I'm applying - putting a small scale into the press would work somewhat for that, to calibrate.
rfmdelgado 5 years ago
Makerneer 5 years ago
GTO3x2 5 years ago
I'm surprised the thin plate at the moving syringe end doesn't walk.
Why isn't the tubing popping apart?
Estimated maximum pressure/force?
misko13 5 years ago
GTO3x2 5 years ago
