How to Make a Watermelon Rose
Intro: How to Make a Watermelon Rose
Watermelon is not only delicious food, it can also be used in various carving ideas. Let me show you today one of these ideas - how to carve a watermelon rose. You can do it and surprise somebody you love. So, let's begin.
STEP 1: Materials Needed
You will need:
- One watermelon
- Carving knife
- Paring knife
- Chopping board
- Small scotch tape
- Plate
- Watermelon and melon balls
- Grapes
- Carved melon leaf (optional)
STEP 2: Peel Away the Green Part of the Watermelon Rind
Wash the watermelon, make sure it is clean. In order to make a flat bottom we need to cut off one side of the watermelon (about two or three inches).
Peel away the green part of the watermelon rind using the carving knife. Be careful in using this knife, do not harm your hands. Peel off watermelon green rind leaving the white round shape. Don't worry if this white shape is not perfectly white. If you peel away too much of the white part of rind and there are some red areas visible, no problem, it will not be visible later.
STEP 3: Cut Out a Circle
Now grab the scotch tape, place it on the center of our carved white shape, draw and cut out a circle using your paring knife. Once you have cut out this circle, use the paring knife to cut out one more bigger circle around the first one. Then remove the white part of rind between two circles. This ring will be the center of our rose.
STEP 4: Cutting Out Petals
Start by using your paring knife and cut out a little piece of white rind in the shape of a crescent near the circle. Then cut out one more larger white rind piece near the first cut and remove it. This process seems to be not easy when you try it for the first time. Refer to the photos I posted for a better understanding.
STEP 5: Center of Our Rose
The closer to the center you go, the smaller the cuts and petals should become.
STEP 6: Triangles
Use your paring knife and cut out little triangles around a rose.
STEP 7: Decoration
Place your rose at the plate. Decorate the rose with grapes, watermelon and melon balls or anything else edible you have at home.
STEP 8: Melon Leaf (Optional)
Give your rose more colorful look by adding one more little thing. I have to say it was my mistake to add just a carved melon leaf. I think it will be much better to add a post card with "I Love You" words.
11 Comments
CatAuror19168 9 years ago
jasara 9 years ago
gracieface2014 9 years ago
summerinhawaii 9 years ago
Passion Make 9 years ago
Amazing !
charlieanderin 9 years ago
shazni 9 years ago
This is beautiful! Thanks for posting along with the video :-)
Tarun Upadhyaya 9 years ago
Stunning :).
creativity123 9 years ago
This is amazing!! Keep up the good work!
doodlecraft 9 years ago
Wow, too pretty to eat! Nice!
