How to Make a Cheap Steadicam
Intro: How to Make a Cheap Steadicam
Tools you will need for this project:
1/4 in. threaded rod (12-20" in. long)
1/4 in. nuts (2)
1/4 in. washers (2) (make sure it's large enough to go past the hole in the weight)
2.5 lb weight (get one with handles)
Total cost should be under 4 freakin dollars cuz it's awesome!
1/4 in. nuts (2)
STEP 1: Screw the Nut
Screw on nut and then slide on washer. They should be about 1 1/2 in on the rod.
STEP 2: Add Weight
Add weight, then other washer, then other nut. Tighten to the point of no movement when you attach a camera.
STEP 3: You're Done!
Now just attach your camera to the top of the mount. Record holding the just the weight. It may take a little practice to get really good at doing this. Don't use a very heavy camera. Maybe use a Flip camera, Kodak PlaySport, GoPro, or something else similar in size. Don't use a large camera though. It won't be very steady and you might break something. I will be uploading some video soon. :) Enjoy!
3 Comments
thegeeke 12 years ago
aschafe7 12 years ago
randofo 12 years ago
