How to Paint Clean Lines
Intro: How to Paint Clean Lines
Have you ever tried to use masking tape for its intended purpose only to discover that, no matter how carefully you apply the tape, paint bleeds under it, ruining your efforts?
Making clean paint lines between two colors doesn't have to require a steady hand or special equipment. This technique is very simple and requires only paint, brushes and masking tape. This time, however, you will be controlling the bleeding paint and using it to create crisp lines that precisely follow the edge of the tape.
STEP 1: First Color
Lay down the first color, extending past the area where the line will be. If you are using two layers per color, paint both layers.
STEP 2: Taping
Once the paint is dry, place your masking tape. In this case, the bottom of the masking tape marks the location where the edge between the two colors will appear.
STEP 3: Bleed Line
Using the same color, paint along the tape edge. This seems strange but, there will always be some bleeding under the tape. By deliberately painting against the tape, you seal the edge with the first color, allowing it to bleed under the edge, so the second color can't do it. The edge of the tape becomes the edge of your line.
Make sure the lower edge of the paint feathers softly away so you won't see a thick edge of paint later on.
STEP 4: Second Color
When the bleed-under layer has dried, paint the second color. Make sure your paint overlaps the location of the tape line.
STEP 5: The Reveal
Remove the tape by pulling it at a 90 degree angle. Do this when the paint is wet, if possible.
Tah-dah! Crisp, clean paint lines!
(I hate adding a caveat but it seems warranted here: I haven't had any problems with the line when removing the tape after the second color has dried BUT other people I know have. It has to do with paint setting up and binding to itself. So, if you cannot pull the tape while it is still wet or at least soon after it dries, you might consider using a craft knife and a straight edge to score the line before pulling the tape.)
93 Comments
StumpChunkman 13 years ago
But even with the rush, the line came out really nice, straight and clean. Thank so much, it looks awesome!
marydecorator 10 years ago
Looks awesome. This gives me even more hope of this working for my son's car! :)
FloF9 5 years ago
ok but what about painting a circle?? How to make it perfecty sharp? Impossible with a tape technic cause it s round!
Texan786 3 years ago
Here's a (hopefully) more intuitive description instead of a video. I'm painting my ceiling white and my wall dark blue.
1. I paint the ceiling white going past the corner edge and splashing the white paint down onto the top of the wall (the wall can either be the old color or the new beautiful blue). Let it dry thoroughly.
2. Tape against the ceiling onto your fully dry white paint. Use painters tape (usually blue) as it's made to stick to paint but not pull it off the wall. Be sure to at least reach the corner edge. If you can't hit the corner exactly then over-run onto the wall a little, it's barely visible. Tape in long-ish stretches so you have less wiggle in your line.
3. Now you expect to start painting your wall blue but DON'T. Paint *more* white on top of your wall. Some of this white will slip under the tape onto the already white ceiling. (Other people point out that you could use something else here like clear sealant or something but you have the white paint right there, right? Exact match.)
4. Let the white paint mostly dry as you obsess compulsively over how invasive that ragged white line looks trespassing onto your wall. Once dry, cover up the white up to and onto the front edge of the tape as you have been waiting to do. The blue paint cannot run under the tape because the white paint already did that and sealed up the gaps. A darker color will more easily cover the white. If you have to paint a light color over dark, let the first mostly dry and do a second coat at this point before pulling tape.
5. Let the paint mostly dry but for slightly better results, pull off the tape while it is still moist enough to tear cleanly and easily. If the white over tape dried fully, no problem, the new paint will moisten it up slightly so it tears cleanly.
6. Lie to your friends that you 'just eyeballed it' but think it came out pretty good.
kenny.saus 5 years ago
Sorry. This is really confusing~. Agree, post a video
caramountpics 6 years ago
Very excited to see how this turns out!
Question though: My first colour is a light grey. My second colour is a white. I want the white to be really bright and poppy, which means I want to do two coats of the white. I've already taped, applied the light grey and have let it dry.
Now, should I:
1. Paint the 1st coat of the white. Then while it's wet, peel off the tape. Then once it's dry, retape the edge and apply the second coat? (with no light grey?)
OR
2. Paint the 1st coat of the white. Let it dry. Paint the 2nd coat of the white, then while it's wet, peel off the tape?
garling37 14 years ago
Morganbarker 14 years ago
nehmo 6 years ago
A 1/16 inch gap would be visible even if it's in a junction between the wall and the ceiling. Are you saying leave the very top of the wall unpainted?
garling37 13 years ago
przemek 14 years ago
------ 13 years ago
It's kinda like the same method to pop a chalk line.
finfan7 14 years ago
cfedonczak 7 years ago
Genius trick, filling the tape edge leakage with the color that you are masking.
Ccincalifornia 7 years ago
CraigS69 8 years ago
why not just use the brown then pull tape back? Doubling uo with the green first then brown seemed to np be an extra step!! What am I missing?
Looks as the brown covers all the lighter color either way!
KirkF8 7 years ago
this is old but I'll comment anyway.. by painted the tape edge green also you are controlling the paint that will bleed under the tape do to the texture of the surface and this fills in the tiny spaces with the same color. If you put brown on directly it would bleed in those tiny spaces and you will have a jagged line. So you're making a jagged line but of the exact same color and filling in the gaps, then when you paint the next color it doesn't bleed because the tiny gaps are already filled in so you get a nice crisp line... Cheers
kaystone 9 years ago
