I saw some old plans from a do it your self book on making a canoe using a process like this. They used Shellac I think. I'd like to try a kayack with this method.
Well done. It is surprising that you haven´t used any epoxy resin. It would have made the boat walls more "plastic", but would have increased expense as well (which somehow would defeat the purpose of using paper to begin with...). Obviously you have been watching other cardboard boats before going on --the inspiration shows-- and you have improved upon them, but I am also surprised that you --or the other guys who built paper boats-- do not treat cardboard the same way plywood is treated; i.e. you guys do not design paper boats with the same criteria used for plywood boats. Namely, I have the Six-Hour canoe or the www.bateau.com plans in mind, which are very simple designs out of plywood. Generally speaking, what you do with plywood you could do with cardboard, so I don´t see a reason not to design a more rounded, a more hydrodinamic boat out of cardboard instead of having those sharp angles and edges. You might be the guy to lead the way.... All the best and, again, congratulations.
For now I'm just leaving the newspaper showing - I like that look. So did the local newspaper, since their paper is covering the hull! They published a little write-up on it, along with a photo.
X
Autodesk Instructables
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
7 Comments
meddler 8 years ago
JoshuaCope01 9 years ago
really awesome, ill try and build it
moratelli 10 years ago
claudg1950 10 years ago
ironicbliss 10 years ago
Lorddrake 11 years ago
EldonMartin 11 years ago
