How to Colour Steel With HEAT
Intro: How to Colour Steel With HEAT
How to colour steel with heat (hot oil finish) is a simple but effective way of achieving a desired colour of choice.
The colours are fantastic and often come out in a beautiful two-tone shine. There is something really rewarding about this technique. Not only does it give you an alchemical feeling of satisfactionbut it also gives the metal a finish to stop corrosion.
STEP 1: Preparing Your Materials
You will need:
-2x containers (one of them preferably being metal for the oil)
-oil
-unleaded petrol/Acetone/Terpentine/Rubbing alcohol or any good degreaser
-metal object/s (I used mild steel, Please note this method should NOT be used on tempered/hardened steel as you will effect the properties of the metal)
-something to hold your object with i.e. pliers, mole grips,...
-heat source
-protective glove (optional)
-wet towel on hand for safety
In Explanation:
-An old metal container (I know, a plastic container is pictured but always use a metal one) filled high enough with oil to completely submerge your steel object would be ideal. You can experiment ultimately what oils to use. Try it on some unimportant pieces first. I found through my bluing adventure that different oils do act slighty different but ultimately everything I've used has done the job. For this Instructable I'm using thread cutting oil. I have also had good results with 5w/30 motor oil, I've also used two-stroke oil with good results. It's worth noting that there can be some additives in motor oil that release hydrocarbons when burnt which is a known carcinogens to the body (in other words: Bad Stuff!)
Your container should be relatively larger than your object.
-An old container filled with your chosen degreaser (unleaded petrol...)
-Your desired polished metal object/s (very important!: Make sure it is made from Mild Steel or Titanium. You can not do this method with Aluminium because it won't reach the temperatures required for bluing, it will just melt. Trust me, I'm speaking from experience :) )
I have cut and polished 4 pieces of mild steel to demonstrate different colour stages. The object on the left is a custom mild steel potentiometer knob!
-Something to hold your piece with, make sure it's appropriate to hold it with so it doesn't get too hot in your hands. It would be a good idea to get some gloves on.
-A heat source. That can be a pen torch (pictured), a blow torch, a heat gun, a gas hob (which I am going use) or anything that will provide you with enough heat.
Please note: As you are working with heat, please be smart, use your common sense, do the bluing process in a well ventilated area and keep a wet towel to hand.
STEP 2: Cleaning Your Metal
For the process your metal should be nicely polished for the best results.
The more shinier the polish the more your end result will glow.
I can't stress how important the degreasing step is! Do NOT wipe/touch your metal with anything after degreasing as the whole purpose of cleaning was then for nothing. Even a fingerprint will affect the consistency of the colour.
Now securely hold your piece with whatever you have chosen.
In my case I drilled/threaded the metal piece and made a holder with a threaded end. This is not necessary as long as you can hold your item appropriately and not cover where it is to be heated.
Next wash your piece in your chosen degreaser for a minute or so to get rid of all grease/fingerprints that was on the metal.
Then remove it from the degreaser, don't be tempted to wipe it off with anything. Just let any residual matter evaporate/dry.
STEP 3: Bluing
Now you can start.
Apply heat to your object and heat up gently and equally.
As I'm bluing round pieces I slowly and evenly rotate the piece over the flame to equally disburse the heat.
Be patient in the first few minutes as the metal needs to reach the temperatures where it changes colour!
Once you see it turn golden, the process has started and colours will change fairly quickly!
Sometimes at this point, I come just a fraction away from the heat to go through colours a bit slower.
It will first turn gold, then orange, then red, purple, blue and then dark grey!
STEP 4: Finishing
Once you get the colour you want, go outside to your oil container and fully quench your object into the oil!
Note: I know a plastic container is pictured but always use a metal one!
Bear in mind not to touch the walls of your container as you don't want to disturb the process of what's happening!
Remember the oil is probably gonna release some smoke/fumes once the piece is quenched so as said before: please do this step in a well ventilated area.
Once it's cooled down, take the object out of the oil and place it on a piece of paper/cloth and let it set for about 20 minutes. Alternitavely you can leave it in the oil bath to stabilize.
Then wipe off all excess oil and look at your beautiful finished object!
STEP 5: Admire Your Finished Product
Above you can see some example pictures of the colour shades that can be achieved with this techniques.
Have fun doing it!
58 Comments
shycut30 12 months ago
corradini 5 years ago
I'm trying to be positive and constructive, and think this is: for an amateur to stick a very hot torch-heated metal object into a plastic container filled with oil is simply dumb (ok, more polite: "irresponsible") at best, highly dangerous at worst. I'm a professional knifemaker and use many very high-temp methods including quenching 1,600°F steel in pre-heated oil - I know what I'm talking about, 'cause I still have 10 fingers and my eyesight. You'll probably be fine following these instructions - you'll probably be OK driving home a little drunk, too. I wouldn't recommend either.
gparton85 3 years ago
corradini 3 years ago
You're ABSOLUTELY right. I think I was drinking heavily (and likely doing stupid things in my shop with high heat and flammables at the time, possibly while juggling chainsaws) at the time I made that comment - without reading carefully. Mea maxima culpa - and I left my comment up rather than delete the thread (for now) just so I could reply and admit the My Dumb, rather than skulk away cleanly... >;-)
jdp67.7272 3 years ago
Thanks, Joe
bertram52 4 years ago
CorinneO3 6 years ago
I don't understand why you are submerging it in oil? Isn't the point of the acetone to degrease, why would i grease? I am using bronze, is it for a polish?
Irritable_Badger 5 years ago
Akajira 6 years ago
thebear1 9 years ago
looks nice but you are using what is known as heat treatment which will darken steel
not using bluing salts as in gun bluing of rifle barrels all in all very nice instructable
sorry my 2 cents
FievelM 6 years ago
I found that heating will turn steel silver ~> gold ~> violet ~> blue. I believe the change of color is due to a growing thickness of an oxide layer. (meaning oxygen atoms are able to attach themselves to the outer layer of the steel)
We did this with an electromagnet! Check out the video:
https://hackaday.io/project/21947-makers-vise/log/60914-coloring-steel-with-magnetism
Chris Project 7 years ago
what kind of oil are you using?
RandyD63 7 years ago
Boverpho 8 years ago
MandalorianMaker 7 years ago
highfour305 9 years ago
JohnL595 7 years ago
Usually they would pack the parts in crucibles and surround them with leather, wood, coal,bone etc...They would heat them up to 1200°F to 1500°F and hold them at this temp. for 6-8 hours. Then the crucibles would be removed from the furnace and placed over boiling hot water and air would be bubbled through the water and the parts would be dropped into the water. The differing rate of cooling for each area produced a different color creating that rainbow effect. All those materials the leather and bone the coal where sources of carbon and other trace elements. The steel was mild steel and had very little carbon content. This is how Colt made their rifles and pistols prior to Civil War you can read all about the process. The book claims they used wait for it "boiling gasoline" not making this up to clean them. If I remember right they then heated them up a bit and applied fish oil orignal and I think latter switching to linseed oil to protect the finish and give it that wet look. This is all from memory so I might have left some stuff out. After the Civil War they switched to another process. You can also heat the oil to create different effects. Cooking off the more volatile hydrocarbons leaving the heavier ones produces a different effect yet again. Have proper ventilation and use proper modern safety gear!
Midgaardssmeden 9 years ago
highfour, case hardening is a bit different from what you describe.....
Usually, the steel needs some time in a medium that will allow carbon to penetrate the surface, and we are talking 15 minutes to several hours....
Nowadays, even mild steel does have a certain amount of carbon in the alloy, which can explain your observations, if you google "super quench," you should find a waterbased quench that is rumoured to do the same, but in my humble opinion, water can do just that as well....
But hey, as long as it works....
Tallanted 9 years ago
Ok you gotta help me out here...when I was studying mechanical engineering a good few years back a project I done involved using a compression fit of 1/4" thick plate steel into 1" thick steel rod, both mild steel. The rod was heated and the plate 2" square was inserted and the rod shrunk onto it. The plate turned blue just like you ible and I was told this was an effect of compression fitting....the rod didn't change colour even though it had the heat applied to it so was it actually the compression fit that changed the plates colour
bpark1000 9 years ago
The "turning blue" process has nothing to do with hardening of the steel, or its compression. It is caused by a layer of oxide that forms when the steel is heated. The thickness of the oxide is a function of how hot you heat the steel (The color is due to interference of light reflecting from the surface of the oxide coating, and light reflecting from the oxide-steel interface). The hotter the steel, the further the oxygen can diffuse through the oxide coating, so the coating builds thicker before it protects the steel from further oxidation.
To shrink, I assumed you heated the steel plate only, to expand the hole in it. This heating forms the blue on the plate. Now you slide the cold rod in, and the plate cools, gripping the rod. While the rod may heat some by conduction, it wouldn't get hot enough to start the color-forming process. (You say the rod was heated, but it couldn't have been, as it was on the inside. You heat the outside member only when you do a shrink fit.)
For hazzalandy: carbon content has nothing to do with the color process, it is only the temperature you heat to, and to a lesser extent, the time spent hot.
