How to Fit an 2,5" PATA HDD in 3,5" HDD Case
Intro: How to Fit an 2,5" PATA HDD in 3,5" HDD Case
Yesterday I got a computer that had a broken HDD. I had a 2.5 "HDD, so I decided to install it in computer, but it's too small, so i put it in 3,5" HDD case as follows:
Required items:
-broken HDD (3,5")
-workable HDD (2,5")
-2,5" to 3,5" PATA HDD adapter (http://www.ebay.com/sch/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=%09+2.5%22+HD+to+3.5%22+IDE+Hard+Drive+HDD+Adapter&_sacat=See-All-Categories)
-a smal saw
-Hammer
WARNING, do not squeeze, bang or shock HDD, otherwise you will break it!
Required items:
-broken HDD (3,5")
-a smal saw
-Hammer
STEP 1: Disassembling HDD
To disassemble the HDD you need to unscrew the top screws and remove the top cover.
The steps are shown in Figures.
STEP 2: Cutting a Piece of Case for Connectors
To connect the drive we need the connectors, so we have to cut a piece of the case:
STEP 3: Cutting the Thread
To make sure that the connector does not move, we have drilled two holes and tighten it:
STEP 4: Done!
When you made the previous steps, your hdd sould look just like one on the picture, then just put back the cover and screw back the screws.
STEP 5: Try It!
to try it, just connect the HDD on computer!
3 Comments
caitlinsdad 12 years ago
race_king 12 years ago
ironsmiter 12 years ago
More evidence is given by the VelociRaptor hard drives.
google image search for WD VelociRaptor.
also, since it's hard-mounted to the old drive... any shock mounting form the external case is re-used... so no additional absorption is called for.
