How to Make Hydrogen
Intro: How to Make Hydrogen
Hello I will start by saying that this is my first instructable and would value any input that may lead to improve this article.
I would also like to advise everyone to take safety precautions.
DANGEROUS THINGS ARE DANGEROUS you get it?
Throughout this article I will show you how to create, store and use your hydrogen.The hydrogen you will be making utilizes the hydrogen producing reaction between NaOH (SodiumHydroxide) and Al (Aluminum) in the presence of water. I will not go into the chemistry here, however, if you wish, Google will hold the answers.
STEP 1: Materials
You will need the following materials to make, store and use hydrogen.
1. Drain Cleaning Crystals (Sodium Hydroxide (NaOH))
2. Aluminum Foil (1Meter or so will do)
3. A Beverage in a GLASS bottle
4. Balloons
5. Ignition source
6. Water
7. AND MOST OF ALL SAFETY EQUIPMENT
4. Balloons
5. Ignition source
6. Water
In total all this cost me less than $15 dollars Australian.
STEP 2: Preperation Step 1
Drink Beverage.
STEP 3: Preperation Step 2 - 3
Setting up the Reaction Chamber (filling the bottle)
1. Get yourself to a well ventilated area.
2. Get a bucket of water and grab some safety glasses if you wish.
3. Pour about two tablespoons of the Drain cleaner into the bottle depending
on the size of the bottle and strength of drain cleaner.
4.Get a reasonable length aluminum foil
5. Fold this foil into a long bar and force into bottle (don't worry if most of the foil is not touching the NaOH as it will eventually fall in. And If all the foil was at the bottom the reaction would be too vigorous )
STEP 4: Starting the Reaction
1. 1/3 fill the bottle with water
2. Watch the reaction go.
The reaction takes a while to start however, within seconds the water will be almost boiling(this is an extremely exothermic reaction).If the reaction gets too hot most of the gas released will be Steam(which is pretty much useless).In order to slow the reaction tip water on the sizes of the bottle or place the bottle in a water bath.On the other hand if the reaction is to slow you may need to make sure that you add more aluminum and NaOH next time.I have also included a video of the reaction bubbling away for your interest.
STEP 5: Collecting Your Hydrogen
Ok to collect your hydrogen you need to immediately place a
balloon over the top of your bottle after pouring in the water.
If you do this right your balloon will be lighter than airhowever due to the steam produced in the vigorous reaction from the foil used you will get better results usingsolid aluminum.When your balloon looks full pull it off. '''WEAR GLOVES '''then tie it off and now you have your own mini Hindenburg(Watch out though blowing up this balloon should be done at a safe distance and is really loud).
STEP 6: Ok Your Pretty Much Done
However, if you want more fun you can always put more reactants into the chamber (bottle) and light the top.Depending on the rate of reaction and the amount of steam produced you shouldhave a self sustaining hydrogen lantern.This lasts about 10 minutes maximum.
131 Comments
hho1960 1 year ago
lasermansx 3 years ago
TrailblzrX 11 years ago
stan754 6 years ago
the hydrogen gets extracted from the water so no you cant do it without
steven07 11 years ago
Perhaps if you wait for the reaction to finish you the water will cool down condense and leave the balloon back into the bottle.
The ice bath sounds like a great idea, other ways which you can slow down the reaction and reduce the heat generated per unit time include using chunks of aluminium with a lower surface area.
PsychedelicFish 14 years ago
ндогонят 6 years ago
No, just hydrogen, aluminium oxide and heat. Aluminium oxide remains in the bottle, heat transforms the water into steam. Passing the gases (H2 and steam) through ice in a vertical pipe/tube condenses most of the steam (H2O gas) back to water (H2O liquid), so you should only get H2 (always gas in this temperature range).
GAMEJOE 7 years ago
How many minutes to wait until the balloon grows.
AppuN2 8 years ago
can i make hydrogen gas with ice (not a dry ice) , aluminium foil , salt
fwjs28 15 years ago
agent harmsy 14 years ago
chip123 14 years ago
Cobalt59 13 years ago
LuisG87 8 years ago
finniano 13 years ago
FelipeB1 9 years ago
won't the NaOH corrode the glass bottle?
Kinnishian 9 years ago
Nope, it's glass. Glass is incredibly resistant to most chemicals.
treesap 9 years ago
False. While glass is resistant to most chemicals, sodium hydroxide is indeed mildly corrosive to glass. It's fine for a project such as this; however, if storing lye long-term, or heating a sodium hydroxide solution, glass is probably not the best choice.
Kinnishian 8 years ago
you are totally correct :)
