How to Make Japanese 6-1 Maille Armor
Intro: How to Make Japanese 6-1 Maille Armor
Much like Japanese 4-1, 6-1 is a simple weave but provides greater strength and protection than Japanese 4-1. The method is slightly different because Japanese 6-1 does not form square-shaped patterns.
STEP 1: Row 1
When making a Japanese weave, two different ring sizes are used; the larger rings are connected together by the smaller rings. To start Japanese 6-1, Take as many of the large rings as you want and connect them to each other in a long strip with the smaller rings. The pattern should be: one large ring, one small ring, one large ring, one small ring, etc. See picture below for clarity on this step.
STEP 2: Row 2 (Part 1)
Now create a similar row that has one less ring than the first row. Place this row underneath the first row, but instead of placing it directly under the rings from the first row, move it a little to the left/ring until the rings are offset. See picture for clarity.
STEP 3: Row 2 (Part 2)
In order connect the two rows, the second row will connect to two of the rings from the upper row. The ring from the bottom row is connected to the ring up and to the left and to the ring up and to the right. See picture for clarity.
STEP 4: Row Three
There should be as many large rings in row three as there were in row 1. Row three should be placed under row 2 in the same way that row 2 is placed under row 1. Connect rows 3 and 2 in the same way you connected rows 2 and 1. See picture for clarity.
STEP 5: Rinse, Repeat
Repeat steps 2 and 3 until you are finished with your piece of Japanese 6-1 maille.
STEP 6: Japanese 6-1 Variations
By doubling the rings you can create two of the most common 6-1 Variations: 12-2 and 6-2. The first picture is an example of 12-2 Japanese and the second is an example of 6-2 Japanese. Hope you enjoyed the last of the Japanese Weaves!
36 Comments
jompon2547 6 years ago
where to buy these ring?
Mar00nKing 3 years ago
HeWantsRevenge 15 years ago
Stop MotionM 8 years ago
You Cant get a template for a head. The only one is on your body. (hopefully.)
drahcus 13 years ago
ineverfinishanyth 15 years ago
LeoP20 8 years ago
How much does it matter if the rings are the same size or not?
Tim P 8 years ago
looks cool, but sounds like it'll take a while...
astral_mage 10 years ago
Tim P 8 years ago
haha love your comment...
marina.cavoli.3 9 years ago
I will do it, soo cool
crowefamily1 10 years ago
burnerjack01 11 years ago
Shut Up Now 14 years ago
acoleman3 12 years ago
naruto the ninja13 14 years ago
native japanese gusari (maille) was never riveted. mainly because the flat or horizontal links were never larger then 16awg x 1/4in and the cross links were never never coiled from larger wire then 16awg. nanaban guasri or foreign maille was introduced from europe in the end of the momoyama period (c16th centrury) and this *was* sometimes riveted. then again, nanaban gusari is nothing but e4-1 hanging the wrong way.
to make so gusari (j4-1) stronger, they just used key ring style links which was named seiro gusari. of course *that* particular weave was woven in the style of so gusari. asa no ha gusari (j6-1) was more rare then that because it took so long to weave and was mostly used in the kote or amoured sleeves and would have hex plates built in to increase the impact resistance of the weave. the worth company sells some oval split rings that are *perfect* for seiro gusari or a seiro/asa no ha gusari hybrid and they're only $23.40/thousand for the size you'd need.
hope this helps! -bows-
H3xx 14 years ago
H3xx 14 years ago
i made a pair of kote once using mild steel 14.5g 1/4 in for the horizontal links and mild steel 16g 3/16 for the connectors with 12 mild steel 18g square square plates woven into the upper arm and 3 mild steel 18g plates for the forearm. it in itself was pretty heavy but it was nice and durable. then again i had actual intentions of using it as armour in case of a knife attack. i was a bit paranoid back then. lol
