How to Make a Foam Helmet Top
Intro: How to Make a Foam Helmet Top
Hello again everyone. Foam-Smith is back with yet another great invention. This step by step guide will help you to make a basic round helmet top. Please note, I will have many more creations along the way based on this model design and to save time, i will specify in that instructable Please refer to foam helmet top . That will help, to let you know that you need to refer back to this instructable to help you in the next step of the design.
STEP 1: Material's
1 (quarter piece) of full camping foam matt.
colored duck-tape
cardboard or anything else you can use to transfer the designs to hard material for accurate shape tracing too later, transfer on to the camping matt
...everyone has been asking me...okay i made a 4 inch line..then went in the middle,so 2 inches in and then went 7 inch up...from there ...I took the for inch line went on each corner and went straight up and mad a square..from the middle point I curved my sides till they meet each end corner of the 4 inch line.. and that is how I got my shapes...Again like I said.. everyones head is different and this method will not work for some..thats why I have mentioned in the beginning to use cardboard until you get your shapes right and then transfer the shape design too your camping matt...I hope this better helps your people
colored duck-tape
STEP 2: Beginning
cut out your 4 shapes of the helmet design, that will later be fused together to make the crown of the helmet
STEP 3:
Begin by taping 2 pieces of the same shape together. start taping from the flat part and slowly work you way up
STEP 4:
When your done doing the first half it should look something like this
STEP 5:
Now repeat the process for the other 2. When all 4 pieces become 2 pieces repeat the same process to put them all together. it should look like this when you are done.
STEP 6:
Next tape up all 4 lines on the out side of the helmet top. Follow all four lines. it should look like this when finished
STEP 7:
Well thats it. your all done.
21 Comments
VaultGirl 5 years ago
it should work the same right? just elongated.
Foam-Smith 1 year ago
HelenaTroy 6 years ago
I've been trying to find a pattern or template for a simple dome, apparently there's no such thing as "simple"! But I can scale this down, thanks very much
Foam-Smith 6 years ago
Anyakin 12 years ago
Foam-Smith 12 years ago
pdevine1 10 years ago
did you end up getting around to making the jpg template?
im having trouble getting to to join on the sides to make a proper curve.
Foam-Smith 10 years ago
yae sorry.. the templeat wont work nor do i have the shapes any more...you will find all the answers u nees in step one.. on the material page...I suggest using carboard to get the right shape then foam.. I realized my templet will not work because everyone has different heads shape... so follow this and u will do fine......
mburton16 10 years ago
Epic 8 mm 10 years ago
The measurments I mad was 7 inch tall-4 inch wide
im very sorry but.. there are know real measurments for that.. you just have to basically eye it.. but I do remember it went something like 7 inch tall by 4 inch wide....because again everyones head is different... because as you fold and bend the size gets smaller.!!Sorry thats really all i can say.....
Georgemk 11 years ago
