How to Make a Cardboard Costume Helmet
Intro: How to Make a Cardboard Costume Helmet
Here's how to make a low cost costume helmet using cardboard. Helmets are usually one of the hardest and most expensive parts to make for a cool Halloween costume so here's a simple method I use. The methods I describe can be used to make almost any kind of helmet but I'm showing how to make a Star Wars Boba Fett helmet as an example - I have an instructable for the rest of the Boba Fett costume.
The templates provided are used by permission from The Wizard of Flight via the Dented Helmet- the definitive Boba Fett costume resource-thanks Alan! The templates are designed to be printed on 8.5" x 11" paper.
For more great scifi costuming templates check out SPC -there's a lot of fantastic patterns there!
STEP 1: Materials
You'll need some cardboard sheet- about 1/16 inch thick material works best. Use the kind that looks like paperboard- corrugated cardboard won't work. The kind I used is called newspaper board and it comes in 30"x40" sheets. It is manufactured by Crescent as well as Arches and is sold at craft and picture framing stores. Crescent shows it on their website as Grey News Mounting Board:
Some people have reported that Ram Board also works extremely well.
You'll also need some white glue, sandpaper, a hot glue gun, some lightweight spackling paste, an X-Acto knife and some Minwax Polycrylic sealer.
STEP 2: First Form the Base
The templates are designed to be printed on letter size paper so just open the files with a program like Adobe Acrobat and print them so they fit on letter size paper. The best way to work with the templates is to cut them out and tape the separate sheets together. I then glued them to the cardboard with some rubber cement and then cut out all the pieces with an X-Acto knife.
The first step is to make the form for the helmet base. This is used to help establish the basic helmet shape and is later removed from the helmet. The form is made from templates pages 4, 8, 11 and 12. The patterns on page 4 and 8 are glued together by cutting a slot in each piece on the center line and then fitting them together. Join the patterns on pages 11 and 12 together and cut them from a single piece of cardboard and then glue that piece to the patterns from pages 4 and 8.
Now make the inner helmet surface. This is done by cutting out the patterns on pages 18, 14,17 and 13, taping them together and cutting them from a single piece of cardboard. This single piece is then wrapped around the helmet base form. Getting the cardboard slightly damp (use a misting spray bottle) will make it easier to bend. Then I epoxy the joint at the back of the helmet.
Next make the helmet outer surface- it is made the same way as the inner surface and is wrapped around and glued to the inner surface. Once the glue is dry cut out the cheekbone sections on the helmet inner surface. Now make the cheekbone sections by gluing the cheekbone template parts together and bending the cardboard and tacking it into place using a glue gun. I only use the glue gun on the inside of the helmet. Then I smear white glue over all the joints on the outside of the helmet.
STEP 3: Making the Dome Frame
STEP 4: Filling in the Dome
STEP 5: Final Shaping
STEP 6: Add Details
The dent on the top of the helmet and the two small triangles on the front were then cut out with an X-acto knife and then a piece of cardboard was glued onto the backside. The dent was then filled in with spackling paste. The rangefinder was then constructed from folded cardboard sheet and then glued together.
There is also a panel that gets glued onto the back of the helmet. This is done by cutting out a rectangular section in the back of the helmet and gluing the panel into the inside of the helmet.
STEP 7: Painting/finishing
The visor is just some tinted plastic that is then glued in. I used hot glue but epoxy putty works really well too and is probably stronger. I then added some foam to the inside of the helmet to make it fit my head so it wouldn't flop around.
That's it- time to go trick or treating!
1027 Comments
starwarsfanatic95 15 years ago
Honus 15 years ago
StarWarsFanCC_2224 1 year ago
syates3 8 years ago
Depending on the amount of work you want to do, you can A. buy one from a dealer for about 140 dollars on the clone trooper forums. B. use Pepakura cut out all the parts, then fiberglass/resin them together bondo the whole thing. Or C. sculpt one from clay then cast it and end up with one as produced by method A.
If you really want one my recommendation is to contact Evo3 he's a fantastic bucket maker he made mine as seen in my photo. The first image is the blank he sent me the second is my paint job.
DaveAnh_Nguyen 8 years ago
Hi syates3 ! your helmet is beautiful ! how much money you paid to Evo3 to he makes your helmet ?
syates3 8 years ago
I think it was 140, for the blank. I spent about 20 hours on and off painting to get all the weathering and details along with taping masking etc.
Thanks for your answer. 140$ ? I live in France so maybe it's complicated. Apparently he doesn't have a website.
syates3 8 years ago
He has a facebook page. https://www.facebook.com/Evo3Props/ You can submit your orders via message and then pay with paypal. I dunno how he handles international shipping though.
We can't see with the helmet in the head ?
syates3 8 years ago
https://www.facebook.com/Evo3Props/ that's his page you can contact him there he also does Tie-fighters, Animated Arc Troopers, Clone troopers and a few others.
blackholeseeker 8 years ago
I would say paper mesche and/or pepakura.
koopatroopa 14 years ago
Anoop101 14 years ago
Honus 14 years ago
Honus 15 years ago
Chicken2209 15 years ago
Honus 15 years ago
noxvox 15 years ago
For those of you who want to make helmets on the cheap, art stores sometimes sell silver reflective paper that looks a lot like metal until creased. For some reason, my school had reams of it, so I used it to make a murmyllow sp* gladiator helmet (one with a fish crest). It stayed in my car for months and I wore it occasionally to scare other drivers.
Mr.NHRA 15 years ago
