How to Make a Disposable Camera Infinite
Intro: How to Make a Disposable Camera Infinite
Alright so i was messing around with a disposable camera the other day and found out that theres a little gear under the covering of the camera that if you turn it to the right will make the camera take infinate shots.
***WARNING: ELECTRIC SHOCK HAZARD, and be VERY VERY CAREFUL when using fire!***
STEP 1: Take Appart Camera
now we have to take the disposable camera appart. the camera has a big sticker wrapped all around it, you wana take that off (DO NOT USE WATER. after the sticker is off use a screw driver and push it under 1 of the little clips on either side of the camera.
STEP 2: Make the Opening
ok to make it so that you can turn the small grey gear to make the camera go forever. To make the hole you can do it in 2 ways
But befor you do anything mark where the grey gear is.
1. you can drill/stap a hole in the back of the casing to spin the gear.
2. you can do what i did and burn then cut the exces off
STEP 3: Battery
on the left side of the camera is a battery. when this battery dies, then the flash dies, so change the battery, and now you can
STEP 4: Finished
ok were done all you gotta do now is put the case back on (just snaps on) and away you go
PS. i havent tried putting another roll of film in it yet but im pretty confidant it will work (try it if you want and post as coment if you do)
I put a video of what you do after you re-assemble the camera
21 Comments
TehMessiah 13 years ago
saxmaster765 12 years ago
Oh . . . Thank you, battery.
jeffconnelly 12 years ago
vbexpressrocker 12 years ago
Acidmoxy 12 years ago
To load film into a disposable camera, you must pull the entire roll out of the canister and wind it around a spool on the left. So before you've even started taking pictures, you've exposed the entire roll of film.
The reason disposables are built like this is so each time you wind on after taking a shot, the film is pulled back into the carrier, rather than out of it, like with regular cameras. That way, they can be pulled open and the film is ready to be developed. Also, it's cheaper to manufacture as the camera doesn't need to have any kind of winding mechanism to pull the film back into the carrier.
thegentleone 14 years ago
Wesley1 14 years ago
bylerfamily 14 years ago
westfw 15 years ago
DarkStar851 15 years ago
slim90 15 years ago
CameronSS 15 years ago
Kiteman 15 years ago
PointyOintment 15 years ago
fluffy29 15 years ago
two, actually
killerjackalope 15 years ago
goeon 15 years ago
