How to Make a Fake Virus on a Windows Pc
Intro: How to Make a Fake Virus on a Windows Pc
Hi guys! today i have an april fools prank. its not a real virus and will not do any harm to your computer. it is just a shortcut.
STEP 1: Notepad
to start open notepad and copy the text i have on it. then press file, save as, and save it
STEP 2: How to Open the Fake Virus
press start, search "virus" ( mine was under virus yours might not be.) find the file and open it. your done. thank you and please vote for me under contest, april fools pranks.
9 Comments
hheightman 7 years ago
What you've written is called a batch file and batch files are as old as as the earliest releases of DOS some 35 years ago.
Batch files are to DOS and Windows what shells are to Unix and Linux. While not as powerful as the latter, they are nonetheless a very useful tool.
Regarding your "virus" batch file:
You can get the same result using only the first 4 lines of the file. As soon as it reaches "goto hack" statement it will return to line 2 and continue looping. The rest of the file is unnecessary.
If you want to slow it down, as signaltcl asks, give the processor some busy work before looping back to the ":hack" label.
Here's a modification of your idea that runs a bit slower and has a few suggestions embedded.
@echo off
:hack
echo downloading virus
echo overwriting drive data
:rnd1
set one=%random%
if %one% gtr 100 goto rnd1
:rnd2
set two=%random%
if %two% gtr 100 goto rnd2
:rnd3
set three=%random%
if %three% gtr 100 goto rnd3
goto hack
Notes:
1, Having more than one echo command will cause some screen activity,
otherwise, after the screen is filled once, it will appear static
2. The command "@echo off" need appear only once, at the beginning of the file.
3. If you want to slow it down, give the processor some busy work. In this case, I have it generating random numbers and repeating the process until it generates a value of 100 or less. To slow down further, add more randomizing operations OR decrease the maximum value of each random number. I borrowed this technique but I can't remember the source.
signaltcl 8 years ago
how to make it read slowly?
iman4 10 years ago
carrotman42 11 years ago
@echo off
:hack
echo downloaded virus
goto hack
be easier?
iman4 10 years ago
pranjal12 11 years ago
pianolover10124353 11 years ago
16405 11 years ago
