How to Make a Quick Cheap LED Flashlight With a Stick of Deodorant!
Intro: How to Make a Quick Cheap LED Flashlight With a Stick of Deodorant!
In this Instructable, I will show you how to make a coll quick, and cheap LED flashlight out of a stick of deodorant! (and a few other parts)
STEP 1: Collect the Parts!
You will need:
Parts:
1: 5mm LED's (1-6)
2: 330 Ohm resistors (one for each LED)
3: 9 volt battery (1)
4: 9 volt battery adapter (1)
5: a switch (optional)
6: a project enclosure (I used an old deodorant case)
Tools:
1: a soldering iron
2: solder
3: a drill (or anything else that will make a 5mm hole in your project enclosure)
4: your hands
(Sorry, the picture is really blurry)
Parts:
1: 5mm LED's (1-6)
Tools:
1: a soldering iron
2: solder
4: your hands
STEP 2: Deodorize!
Use the deodorant!
STEP 3: Decorate!
Remove the label, and decorate your enclosure as you like!
I just left mine black, because I thought that it looked best like that.
STEP 4: Connect!
I connected the LED's in parallel, so that I could not accidentally burn out all of them at once.
Solder all of the negative leads on your LED's together.
(the negative lead will be shorter)
STEP 5: Resistance!
Now, solder a resistor to each positive lead of the LED's
Then, solder all of the resistors together, above the actual resistor!
STEP 6:
Now, solder the negative(black) wire from the battery adapter to one of the negative LED leads.
Next, I connected the positive(red) wire from the battery adapter to one of the resistors through a flip switch, but you can use anything to connect them, you could even connect it directly, but the LED's would burn out pretty quickly...
STEP 7: Drill!
Next, drill one 5mm hole for each of your LED's on your project enclosure.
I put one hole in the side of mine for the switch.
STEP 8: Put It All Thogether!
Now, insert your LED's into the hole that you drilled in the project enclosure.
I put the switch in the hole that I drilled for it.
now close, put the lid on, or seal your enclosure.
YOU'RE FINISHED!!!
YOU'RE FINISHED!!!
23 Comments
DavidKaine 15 years ago
jbv6 15 years ago
jbv6 14 years ago
stratos13pao 15 years ago
jbv6 14 years ago
anafam 15 years ago
finnrambo 15 years ago
jbv6 14 years ago
masterochicken 14 years ago
fllynt 14 years ago
allegfede 15 years ago
cyrozap 15 years ago
jbv6 15 years ago
the_don125 15 years ago
For example, if you test with some slightly used alkaline batteries, they might be at 1.5V each, but after you assemble everything and put in fresh batteries, those new batteries could be as high as 1.8V each, a major increase, easily enough to blow your LEDs!
Also, red LEDs take 1.8V-2.2V (even for the superbrights), not 2.7
Skyfinity 15 years ago
jbv6 15 years ago
