How to Make a Survival Paracord Belt Using Only Two Cords!
Intro: How to Make a Survival Paracord Belt Using Only Two Cords!
I saw at an online army store a really awesome paracord belt. It packed in 125-200 feet of paracord. Well mine doesn't pack as much paracord, but it looks almost the same!
This version is a very smooth one. It goes through the belt loops very easly if you tighten the paracord a lot. This belt unravels to about 50 feet of paracord. You could easily weave this into a hammock if you wanted too.
There is not many steps because I crammed all of the braiding instructions on one step.
STEP 1:
All you need is:
-(two) 50 feet of paracord (two different colors)
-(two) D-rings
-Webbing (Check the picture notes)
-(two) D-rings
STEP 2: Starting Up
This part is easy.
All you have to do is roll the paracord on a paper towel tube or a wood stick. This helps the projecta lot easier. You will see why later.
You also need to get the webing and wrap it around your waist. Find the folding point where it has two strips of webing but were the shorter end stops the longer end is a foot long. Then put the D-rings through that fold. Sorry I couldn't have a picture for that part.
STEP 3: Begining the Braid
The instructions are on the image notes. (Sorry, I didn't want to type it all over again)
It is just the simple paracord braiding technique. For those who don't know how to do this, here are the instructions. (I am a visual learner so I like to do the instructions by pictures.)
STEP 4: Finishing Up
Here are some pictures of the ends being melted off. This part is simple.
When you are in the wild, and you don't have a tent or flat surface to sleep on, you can weave this belt into a hammock!
23 Comments
sonic broom 9 years ago
cool i might try this
mcgaughp 9 years ago
I used a different type belt for mine. I purchased a pair of cargo pants at WalMart and a small cloth belt came with it. The belt was perfect for this project. I also purchased a few web belts at an Army Surplus store and plan on adding paracord to them someday.
It's easy to make. You should try it.
aliengolf50 10 years ago
Very cool idea!!!
RoboTronics21 11 years ago
drumsetmonkey 12 years ago
punkhead58 12 years ago
usseryscoutleader 12 years ago
I also like it because I have 88' of uncut single color of cord, and I still have a belt. It looks nice and it does feed thru the loops easily as descriped. I found this method to roughly equal 2' of cord per 1" of braid.
Very nicely done! My next belt will be two colors!
dave72 12 years ago
mysss 12 years ago
Count Almasy 12 years ago
rgreene3 12 years ago
jbabcock1 13 years ago
knota 13 years ago
Chanio 13 years ago
Your project gives form to what I was envisioning...
I am planning to do the same but to wrap my bicycle's top tube.
The idea is to change just a little of your project to achieve this:
Instead of using two cords, I'll just use one that would fold in two!
This way, when required, I could unweave it all and have a single cord!
Instead of using the webbing, obviously, I'll be using the bicycle's top tube...
I'll try to publish my finished project when done.
Thank you, again!
lebeef143 13 years ago
knota 13 years ago
AlecGoodwin 13 years ago
knota 13 years ago
jeffconnelly 13 years ago
knota 13 years ago
