How to Make an Hourglass From Two Lightbulbs
Intro: How to Make an Hourglass From Two Lightbulbs
In my first Instructable wilI show you how I made a fancy hourglass.
Lightbulbs are becoming cheaper because they are been replaced by cold light lamps and LED´s .
So ,if you you have two fused lightbulbs ,reuse them into.. an hourglass!!!!
STEP 1: The Materials
What you will need:
- Two lightbulbs of the same type
- Sand, preferably from the sea shore.
- A screw
- Some wood
- An empty can or any piece of thin metal,alluminun works great.
- Some paint for the base.
- Hidrochloric acid (you can avoid this if your sand is clean)
- A screw
- Some wood
STEP 2: The Tools
Tools you may need:
- A saw
- A pin
- A hammer
- A screwdriver
- Some sandpaper
- A pair of scisssors
- a diamond tool for rototool , one of those use for cutting glass and ceramics.
- A saw
- A pin
- A hammer
- A screwdriver
- Some sandpaper
STEP 3: Cutting the Metal Cap
Start cutting the metal screw cap , holding the glass part wrapped in a piece of tissue paper.
Or you can heat it so the cement will decompose and the cap fall off.
STEP 4: Cutting the Neck
Now, use the diamond tool to cut the part that holds the filament
STEP 5: Preparing the Sand (avoid If You Want)
As you may know, sand consist of silicon oxide, calcium carbonate, and organic matter.
The sand inside the hourglass will pass through a small orifice so it is better if is clean and with homogenous diameter.
STEP 6: The Chem Lab!!!
Rinse with water three times the sand you want to use, removing all the floating stuff.
Slowly, add the acid, BE VERY CAREFUL, USE GLOVES AND A ROOM WITH CIRCULATING AIR,
Decomposing the shell is a quite safe process that only produces bubbling CO2 but the foam can overflow.
Once the bubbling ends , rinse and clean with water until all the mud is out.
STEP 7: The Base
I cut a wood rectangle and partially emptied the bottom.
The passing hole is for holding the arm.
Then I fill it with melted lead. (again be careful because it is HOT¡)
STEP 8: The Collar and the Sand
With a pin pierce the center of the metal disc. Not too small so the sand can´t pass, not too big so ... you run out of time!
Fill the bulb with the dry and clean sand
Place the disc over the hole and fix it with a bit of glue.
Now you can put it inside an oven to remove all partial humidity it can remind if you work in an humid area as I do.
Place the second bulb on top of the first one. NOW, THE NEXT STEP IS THE NO RETURN POINT SO YOU MUST BE COMPLETLY SURE OF ALL THE PREVIOUS STEPS .
Glue with with epoxi.
When dry , wrap some cotton thread or fabric., so it will look nice.
STEP 9: Final Step
Mount every thing.
That´s it !
Questions and suggestions are welcome.
That´s it !
17 Comments
Yonatan24 8 years ago
Hi, I've added your project to the "Unusual Uses for Light-Bulbs" Collection
This is the link If you are interested:
https://www.instructables.com/id/Unusual-Uses-for-L...
Caodiie 14 years ago
Thank you a lot for posting this tutorial, totally awesome. :D
XLY 14 years ago
Maybe, and only maybe, after marking with the metal saw all the circumference where you want to have the cut , you can try to heat up that contour with an alcohol flame and let it cool down at room temperature. Some time that makes a quasi perfect crack, but I moved to the diamond disc because of the better results. Good luck¡¡¡
Thanks a lot!
Father Christmas 15 years ago
imthatguy1125 15 years ago
XLY 15 years ago
pousao 16 years ago
butters8754 16 years ago
spylock 16 years ago
GorillazMiko 16 years ago
LinuxH4x0r 16 years ago
Patrik 16 years ago
CarpetGnome 16 years ago
