forgive me if you have already answered this...but I was curious if you have ever tested the shotgun pouch on this particular model? It seems that with destruction slingshot, a bird pouch would give you higher kill velocity as well as a tighter pattern for longer distances...but I failed physics so I could be WAY off base...;-)
You are wrong, there is no danger to hit your hand. But if you put the handle under the bar, the strain on the wrist would be so high that you would have to shoot ridiculously weak bands.
Did not hear clearly what rubber strap you recommend. Could you please type the name of it? BTW Do you think it would make trouble if the difference in height between the handle & the tubes holding the rubber sling was a half cm more? thanx.
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
6 Comments
Nightmare54 10 years ago
benduy 12 years ago
Mastros 13 years ago
I think the handle, i.e. the middle piece of wood, should have been below the horizontal piece, so that the slingshot will look similar to letter Y.
In this way, there will be no risk to shoot the hand that holds the wood piece, a very likely possibility, me thinks.
JoergS 13 years ago
kenobi 12 years ago
thanx.
tipaklong 12 years ago
