How to Make Cheap Fake Barb Wire
Intro: How to Make Cheap Fake Barb Wire
I needed some barb wire for a costume prop. Obviously I didnt want to use the real stuff because of the potentional for accidents. I could have brought some of the fake stuff but the cost of P&P and the item always puts me off buying them from online stores.
So I thought I'd make use of the things I have lying around the house then I dont have to wait for it to arrive and I could get on with my prop that same evening
It's a very simple and easy technique that I hope people will follow and use in the future.
STEP 1: The Materials
You will need:
String, roughly 2.5 times more string than you want barbed wire.
PVA glue, the staple of many a project
Grey Paint, I used grey poster paint, actually white and black mixed but anything that will mix with the glue will be fine.
Make up a pot of glue. I diluted mine down 1:1 with water, which means it dries softer and is easier to work with. I mixed the grey paint into the glue at this stage to ensure nice even colouring. Roughly 4:1 is my ratio of dilluted glue to paint.
STEP 2: Making the Wire
Take a length of string roughly twice as long as you want the wire to be. This string will have a natural twist from it's own construction. The string I have is twisted clockwise. Tie one end of the string to an object (I trapped mine under a weight on the table) continue to twist the string in the same direction as it's construction.
Now comes the trick for the wire. Carefully fold the string in half, it should start to twist around itself because of the extra twists you just put in the string. With a little nudge you can place these twists evenly along the length of the string. This will form the base of your barbed wire.
Next you need to dunk the string into the glue, make sure it is covered all over and none of the string shows through the glue. The best way to do this is just to accept you're going to get glue all over your fingers and enjoy it. Hang the string up to dry, or curl it up on a surface, just make sure it isnt touching itself or you'll have a gluey mess.
STEP 3: Making the Barbs
Each barb starts life as a length of string about 10cm long. Dunk this string in the glue and coat it thoroughly. Then wrap it around the wire section you prepared earlier. It will try to straighten itself out again so leave it resting on a surface until the glue has set a little.
Once the barb has dried completely then cut the ends at an angle to give it a pointed look.
Repeat this process to place barbs at your own preferred spacings along the wire, before you know it you'll have a long section for your own project
56 Comments
DocW7 5 years ago
DocW7 5 years ago
James NixonS 7 years ago
Amazing idea thank you!
AlessandraM4 8 years ago
I'm going to be making this (about 200' for a concert stage) as soon as my darling gets home from work with the string. Thank you so much. There was no way on this Earth or the next that I was paying $11.50 (CAD) for 7.5' of fake barbed wire. No freakin' way. I used stainless steel coloured metallic paint and darkened it ever so slightly with matte black for an oxidized look. Cost? Five bucks!
JohnF363 7 years ago
Out of curiosity, where did you find fake razor wire for that price? Looking for some right now (price is not an option and I've given up with the internet.
Subjectv 7 years ago
Party City is currently selling some at their store for a fairly reasonable price. I saw it in store (took the picture I attached just a few days ago) that looks pretty decent for the price. Unfortunately the packaging doesn't say how much you get, but you might be able to find more details on their website or in store if you have one close to you. Hope this helps!
JimP29 8 years ago
Aluminum lake 8 years ago
ElizabethF1 9 years ago
where did you get the PVA glue? :-|
a66fordvan 8 years ago
PVA glue is just elmers glue (white glue)
msmont 8 years ago
HamSandwich1 9 years ago
this is brilliant for my wwe figures so they can hit each other
susan.schaefer.758 9 years ago
This. Is. Brilliant. In fact, the only improvement I can think of (and believe me, I KNOW MY CRAFTS) is to use Swellegant in Iron instead of paint, and follow up with Darkening and one of the other two patinas, which will rust the iron, though one looks like real rust, and the other looks like souped up rust from a dystopian graphic novel. You could even add some traces of Blood Red. Yes, their red is genuinely called Blood Red. That's what attracted me to the stuff in the first place. XD
I'm going to have to apply this to some jewelry. I wonder what would happen if I substituted different textures of string, twine, and yarn? Ooh, I wonder what would happen if I used different METALS? Copper barbed wire with green patina would be either Steampunk as hell, or reminiscent of Poison Ivy. (I am incapable of following directions or recipes as written. Usually, this ends well, but let's not talk about the time I watched $35 in candy ingredients turn to charcoal. It still hurts.)
CompGeekie 10 years ago
timingworks 10 years ago
Advar 10 years ago
Nice job, and thanks! :)
psiren 11 years ago
Thanks for the instructions :)
joetubealong 12 years ago
zac_9687 12 years ago
masterochicken 15 years ago
