If it works for you that is fine, just remember that playing back the records at a higher speed will cause excess wear on the needle and grooves of the record.
Thank you. I have used Audacity a very little bit, but never took the time to learn the features you showed. I need to try this with some 33 1/3 rpm LPs we own.
. Tip: For 33-1/3 LPs made since the mid-1950s, you have to apply RIAA equalization, either through hardware (built-in to most amplifiers/receivers with a phono input) or software (a filter for Audacity) if you use a recently manufactured unit without a phono input.
I bought a phono preamp for $40 off Amazon (Rolls VP29). Its about the cheapest one you can find and has everything I wanted except The ability to turn the EQ on or off.
X
Autodesk Instructables
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
7 Comments
onemoroni1 10 years ago
I used the speed feature to record 33 at 45 and convert back to 33 to save time. Since I am not a trained audiophile the result is ok for me.
Mr Cheeseo 10 years ago
rimar2000 13 years ago
Mr Cheeseo 13 years ago
Phil B 13 years ago
NachoMahma 13 years ago
