How to Separate Water
Intro: How to Separate Water
Here's a quick cheap way to get some hydrogen and oxygen.
STEP 1: Gather the Items
You will need 2 pencils,a cup,some cardboard,salt,a 9-volt battery,a 9-volt battery connected, and a pencil sharpener.
STEP 2: The Pencils
Sharpen both ends of both of your pencils.Try to have the graphite in the pencil as long as you can.Then cut the cardboard so it comfortably fits on top of your cup.
STEP 3: Setting It Up
Fill the cup half full with warm water, Mix about 1 teaspoon of salt into the water.Then wrap some of the wire around one end of both the pencils. Attach the other end to the battery. Then you can push the pencils through the cardboard into the water. You will see bubbles around the tip of the pencil.
8 Comments
Max Cordell7 7 years ago
thx a ton i was wondering how to do electrolysis.
cal287 10 years ago
dboss2 10 years ago
WolfgangCanoGuitars 10 years ago
ironsmiter 10 years ago
then you add some dish soap to the water, and watch flammable bubbles form.
simmew2 10 years ago
The Bubbles are Hydrogen and Oxygen. If you can collect them from each pen seperatly by using pvc-tubes, you can use them for other experiments. e.g. hydrogen has a lower density then air, a balloon would float if it was filled with H.
ps: oxygen will appear at the positive lead, negative leads to Hydrogen.
francisdsa 10 years ago
