Hydropower From Reuse
Intro: Hydropower From Reuse
Last fall we were staying at a holiday cottage generating its own electricity from a water wheel. We reproduced that in a little workshop with the kids, powering a LED with a miniature water wheel.
We made several attempts, a number of which worked, but those based on a stepper motors from a discarded printer proved to be the fastest an easiest to make. Furthermore, apart from some glue it was completely built out of discarded parts, thus combining the demonstration of renewable energy with reuse.
We had a great time building and playing. Check out the video to see the result in action:
STEP 1: Reusing Parts and Materials
Reused:
a small stepper motor as found in a printer
2 discarded CD-ROMs
a foam tray
some long stick (I used a piece of 20mm diameter PVC tube from demolition)
a LED
one or two tie-wraps
a small piece of scrap paper
Non-reused: The only non-reused part is the hot melt glue (I recommend the low temp type, especially when working with kids).
Tools: scissors, screwdriver to disassemble the printer (not shown), cutting pliers or desoldering tools for (optional, not shown).
Stepper motors make very easy generators, as they produce relatively high voltages (I’m talking 5V range) at low rpm. Small DC motors (toy motors) need high rpm and still produce only a low voltage (1V range). Stepper motors do not need gears and/or electronics to power a LED (compare it to my junior wind turbine). I was worried about blowing up the LED at first, but that did not happen. The current generated being pulsating very probably contributes to that.
I doe not bother to waterproof anything (motor or electronics). Repeated use for several minutes, on several occasions, showed no need for that.
If found two stepper motors in an old Lexmark inkjet printer for which first the ink heads were no longer available and which later did not survive more than a couple of refills of the last ink head. I guess most inkjet printers will have two stepper motors, one for moving the paper and one for moving the head. The way to disassemble the printer will differ for each model. As in this case the printer should be a discarded one and there is no need to put it back together, you can’t do much wrong by simply unscrewing al screws you can find until you can free the stepper motors. Just keep the pinion gear and the connector they come with on the motors. To give you an idea on what to disassemble, you can go looking for an exploded view of your printer, like this one.
With a bit of luck the LED can also be found in the discarded printer. With even more luck you can find some discarded electronics with a LED standing tall on a printed circuit board, with most of its legs still intact, instead of mounted flush on the board. This makes it easier to remove from the print (leave the legs as long as possible) and easier to connect to the stepper motor by simply inserting it in the plug. As alternative you either us a new LED or desolder one and solder it to the stepper motor leads (I guess it is hard to tell if the ecological impact smaller for using a new led or for (de)soldering).
To keep within the spirit, you can also reuse tie-wraps: when you cut them loose carefully near the “ratchet”, you end up with a shorter, but still usable tie wrap.
Now to start building, see the next step.
2 discarded CD-ROMs
a foam tray
a LED
STEP 2: Wheel to Motor Connection
The wheel is made as light as possible. This makes any unbalance or eccentricity less critical.
One of the discarded CD-ROMs is put flat on the working surface. The glue will stick best on the printed side. Taking this in account we started with the printed side facing downwards.
The working surface as “seen” through the hole of the CD-ROM should be completely covered. With the working surface protected like that, put a good blob of hot melt glue. The stepper motor is put with its pinion in this blob and kept in place by hand, while the glue sets (takes a minute or so). Before it has set look from above to check if it is positioned in the middle of the CD-ROM. Check from several sides to check it is level.
When you are two to do this, it is not hard to achieve a reasonably good alignment this way. The pinion gear helps and we found no spacers or templates were needed.
When the glue has set the scrap paper is peeled off.
With one stepper motor with a metal pinion gear, the wheel came off when using it. The pinion gear was glued back in the hot melt glue cavity, with superglue.
STEP 3: Sandwiching the Vanes
8 vanes, roughly 3 by 3 cm are cut from the flat parts of a foam tray. You could try to use the curvature of part of the foam tray to your advantage (as a kind of scoop type vanes) but I chose not to and kept the water wheel and bidirectional.
The vanes are glued to the CD-ROM already on the stepper motor. We did not mark their position beforehand. Following the pattern show in the pictures, each time putting a van “in the middle” works accurate enough.
Some practical testing showed a second CD-ROM on top is needed to make the wheel-vane construction robust enough. When the glue has set, check the “height” of all vanes and trim those that are longer than the others. All vanes get some glue on top (working quickly) and the second CD-ROM is put on top.
STEP 4: On a Stick and Into the Water
One or more tie-wraps are run through the stepper motor mounting holes and are used to attach it to the end of a stick. Take care the tie-wraps d not hinder the wheel of moving freely.
Connect the LED to two leads of the stepper motor by either inserting its legs in the plug or by soldering. The polarity of the LED does not matter as the current will be alternating. You will need to check which two leads work by spinning the wheel by hand. Several combinations will work, but (depending on the type of stepper motor) not all.
We were able to test our build in the feed to a real water wheel, but you can use any water running at a reasonably high speed. Be careful at the bank: don’t risk falling in the water. :-)
49 Comments
AnnMarie Ha 10 years ago
Hello,
I'm not sure If this is too late but my daughter is making this for her school project and I was wondering if I could find such stepper motor on Amazon.com. I was also wondering what type of foam tray I needed since we do not own any foam trays in our home and if we could buy any on Amazon.com. Also, how long would this project take? My daughter has about a week to complete it.
Thanks, AnnMarie
Also, If I can't find a foam tray is there any other alternative as to foam? Like cardboard or maybe plastic?
Matthew Yang 2 years ago
masynmachien 10 years ago
you can probably find a stepper motor on Amazon. Make sure is is not a geared one, those are less suitable.
If a bottom price is not required, I would recommend this one: https://www.sparkfun.com/products/10551
At only $7 it not that expensive and I used that model with success.
The same product is also available through amazon, but at $9: http://www.amazon.com/SparkFun-Small-Stepper-Motor/dp/B007R9UMFU/ref=sr_1_8?ie=UTF8&qid=1392836223&sr=8-8&keywords=sparkfun+stepper
The shipping options might be better, but amazon and ebay are usually more expensive than buying directly from online suppliers. In this case Sparkfun is a certainly a serious company.
Once you know how to do it, building a working example takes only about an hour. But experimenting, improving and rebuilding it, can keep you busy for days.
As for the foam tray: you need a light and stiff material, that is water resistant for at least a while. So cardboard would not do. Any stiff foam in thin sheet or that you manage to cut in sheets under 1 cm would do. Foam board (stiff foam covered with paper) can work if you carefully peal off the paper. Light wood (balsa or poplar) will work too and should last a while at least.
Stiff plastic sheet, like cut from sturdier plastic bottles should work to. The curved shape can work well.
Please experiment. Anyway, be ready to repair the wheel once in a while. keep the glue gun at hand when the time for a demonstration is ready.
succes,
Yvon
Thank You so much for replying so quickly! You're a lifesaver. Thanks!
sonnyp99 7 years ago
Hi! I'm a senior in highschool and doing a project related to this as a part of a project. For mine, I am making a portable hydropower generator that can be used to charge mobile devices when camping. I was planning on making a stator and rotor to produce the electricity but seeing that I could use a motor, I am thinking of doing that. I am just confused about the motor getting damaged from the water because to generate enough power to charge a phone, the generator will have to be in the water for a very long time. You seem like you're much more knowledgeable on this topic so I was basically wondering if you had any tips on how you would go about doing my project. If so, please respond to this or email me at sonnyp99@gmail.com. Thanks!
masynmachien 7 years ago
Cool project!
First, using a motor as generator is much simpler than build your own stator and rotor. Even commercial small charging devices (think crank torches, some of which can charge cell phones) are often based on an existing motor used as a generator. For a more high end applications it is very often a device specifically built with specs as a generator, but still with the same technology and on the same production lines as motors.
Most low voltage motors, including stepper motors do keep working in clean sweet water for days, weeks and even longer.
It does depend on the type of motor and it is hard to tell in advance.
But most do last quite a while, so if you only need to explore and demonstrate a working principle you can omit any waterproofing.
Dirty and in particular salty water will probably shorten the motor's lifetime considerably.
If however you want to demonstrate how a real reliable product could be made, you should waterproof your motor.
An accessible approach is using waterproof prop shaft assemblies as sold for RC model boats.
Succes,
masynmachien
CristinB2 7 years ago
Hi. How long should each of the stator coils be in length? Thanks.
I just scavenged a printer and used the steppers available from that.
I think it is not very critical if you just want to power an LED.
BorgesG 8 years ago
fgxshgrsdkhfkjh
masynmachien 9 years ago
Thanks!
Hot melt glue is pretty common in DIY and in crafts shops. And Amazon is very reliable.
But you can use other glue, as long as it is water resistant, reasonably gap filling and doesn't attack the foam. If you use another light material instead of foam, you don't need to worry about the latter. You could make even use Duck Tape for the wheel and attach a piece of wood in the middle, with a hole that fits the motor axle or pinion.
Succes!
sciencerobot 9 years ago
Great instructable! Indeed..
Can u give me an alternative for hot glue as it is not available here. And i do not rely on amazon.com and etc... No online shopping..
Kaine_KoG 9 years ago
Great Instructable. Have you ever looked into the Tesla Turbine? This would be a neat project for it.
NicksonB 9 years ago
Doesn't matter if the motor get wet?
Indeed, most motors will survive being wet, even being immersed, for a long time.
And the current lost through the conductivity of the water is negligeable at these low voltages.
4score 10 years ago
Do you think it might be possible to attach 3 LEDs and have them light up when a different voltage is reached so kids can see how much energy is being generated and how fast the water is moving?
Oh yes thanks for the amazing instructables! Great ideas!!
Great idea! That shoul probably work. If needed you can increase the difference in minimum voltage for different colours by adding diodes in series, like I did in this project: https://m.instructables.com/id/Disarming-Game/
Please keep me posted on your results.
Succes!
abifabi 10 years ago
The stepper motor you bought would be useable if only the gears didn't slip when you turn the axle. I altered one once, but that is not a beginner's job.
The maplin motors aren't stepper motors, so they will not do in the concept of this Ible.
this one will work: http://robosavvy.com/store/product_info.php/products_id/2861
I used one exactly like it once.
You do not need a pinion gear. If you have a piece of plastic or wood with a hole that fits the shaft tightly you can work from that. Or drill a hole. Even a drill bit with a diameter equal to the shaft will probably work to make a hole tight enough, if needed with some glue carefully added.
Still, if you ask around there is a good chance someone has a discarded printer lying somewhere.
Succes!
Yvon
