Kinetic Seven Segment Clock
Intro: Kinetic Seven Segment Clock
- This Instructable was created in fulfillment of the project requirement of the Makecourse at the University of South Florida (www.makecourse.com)
This Instructable will not walk you through how to build this clock for yourself. I do not think that the state of this project should be replicated. The clock is currently in version 1 and requires multiple parts to be redesigned before it would be in a stable and consistent state. Instead I will go through some of my design process and talk about issues I ran into. This clock consists of 28 moving segments used to indicate the time. These segments descend into the clock body passing through a light field causing them to become illuminated.
Current Fabrication and Construction issues:
- Planarity issues associates with warped wood.
- Tolerance errors between gearbox, segments, and face plates. Errors cascade due to multiple 3D printed parts that are fastened together.
- Inconsistent gear placement on the servos leads to a couple racks binding and segments getting stuck in an up or down position.
- Some gearbox covers will not entirely fasten due to 3D hole printing tolerances.
- Broken teeth on wood spur gears due to wood quality. All wood parts in this project is either oak ply wood or finishing board (birch?)
Software issues and missing features:
- Gui is not fully fleshed out. I would like to add the ability to change the LED colors and even patterns. I would also like the ability to sync the clock to an atomic clock as well as handle time zones.
- Plans to allow use of the Nucleo calendar and alarm functions.
- There is an issue with the current software that requires a restart after powering up. The GUI currently handles this when the name of the clock is clicked.
- Possible issue with the LED driver software that is not allow full realization of changing color patterns in the digits.
- When setting the time, sometimes numbers that were not intended to change do randomly, possible data corruption in UART.
Electrical missing features:
- Backup battery is not implemented but the pin headers are broken out for the battery. Once in place the internal clock should be able to keep running when mains power is removed.
- Initially I intended to implement a rotary encoder to be used for setting the clock time, I would still like to implement this feature.
I fully intend to redesign this clock from the ground up but I do feel this was a great starting point as I had never pursued a project of this magnitude before.
STEP 1: Manufacturing and Assembly
During the Manufacturing process I went through several spools of PLA iterating through gear box design and tuning the print process at the same time. I also went through several sheets of wood as I had to cut the gears, racks, and segments numerous times. I learned a great deal about milling with the CNC during this project, specifically in relation to squaring, tramming, and keeping in consideration material thickness. I broke multiple endmills getting feeds and speeds tuned properly for my tools. I can only recommend that if you choose to use a CNC for a big project with lots of parts make sure you have run through a few smaller projects first so that you have a better idea of how to effectively use you tools. Don't be like me and fly by the seat of your pants.
KNOW YOUR TOOLS...WASTE LESS
Assembly was very straight forward once all the parts were manufactured, it was a matter of lining up fasteners with their respective holes. This biggest issue I ran into during assembly was the lack of foresight I had in my design related to assembly. At some points I found it difficult to assemble the entire clock by myself. Other times I found I had not left enough clearance between parts for my hands or tools. And I completely neglected any thought of wire/cable routing and management.
I also had significant mismatch between the segments and the face plates, which is why the segments are much smaller than the holes in the face plates. These discontinuities were cased by warping in both the wood of the box and warping in 3D parts. I also neglected to design a tight channel for the rack, so some racks are at slight angles both vertically and horizontally. This is why for version 2 I am going to completely redesign the actuation method for the segments; either a properly design rack and pinion or linear actuators. I also plan on setting up a better way to mount the actuation method in the clock body, as my current design permits slight rotation around the Z-axis of the gearboxes with only two screws fastening them to the clock.
STEP 2: Electronics
Over all I am very confident in my electronics selection and integration. I would primarily focus on coming up with better cable routing and management in the future. The current PWB (printed wiring board) design works well and I have not run into any issues with the board. I would possible look at getting a power supply with a little more wattage capability as I can theoretically draw the maximum current (5V 18A) from the power supply if I was to illuminate all LEDs to max brightness ("White") and moved all the servos simultaneously. I currently have a small delay in my servo control functions so that each servo moves individually before the next one, to prevent this issue from occurring. For version 3 or 4 I would like to design a fully integrated PCB that has the ESP and STM32 processors on a single board so that I do not have to use dev boards. Designing this board would allow other makers to use the board as a starting point for building their own types of mechanical clocks.
STEP 3: Controls and Software
As I stated in the first section, I would like to fully flesh out the control system of this clock it would be nice to add the following features:
- Ability to sync with an Atomic Clock
- Time zone selection
- Calendar and Alarm capabilities utilized.
- Alexa enabled
- LED color control
- LED and servo patterns for dynamic and novel transitions between minutes and hours. This would also require much better tolerances in the over all build quality.
- Rotary encoder for ability to set time without a wireless connection.
There are probably other features that would be nice, but this is what I have written down for the time being. I also need to profile and optimize my code so that I can run the processor at a lower speed and increase efficiency.
For those interested the code base for both the Nucleo and ESP can be found on my github page.
STEP 4: Conclusion
As I stated in the beginning, this instructable is not for those looking to build the current version of this clock, but more for me to get out some of the problems and insights I gained during the process of building this monstrosity. Overall I am proud of the build and I am glad that it actually works. I plan to post instructables related to future versions of this clock as well as other projects I come up with so please keep a look out.
If you have any words of advice, questions, suggestions for features I have not thought of, or just want to say hi, let me know in the comments below.
If you are a student at USF and have not taken the Make Course, I highly recommend that you do. Getting college credit to work on a project you enjoy is a win-win in my book
STEP 5: Puppy Tax
Big thanks goes out to Atom (Sad boy), Eva (Grumble pup), and Astrea (Speed incarnate) for keeping me focused and on task while working on this project.
3 Comments
Palingenesis 2 years ago
To me the Gaps let it down, I think I know why they are so big.
I have an idea, the best way to explain it is a sketch.
It shows guides which will enable you to make the segments a closer fit.
With the guides at the end, they should not interfere with the light.
I didn't draw all the guides, but I hope you get the idea.
magus517707 2 years ago
Part of the problem is also related to gear and rack misalignment, but a guide would definitely help. I appreciate the advice.
I think for the next version of this type of clock will design and build linear servos, kinda like motorized faders on a mixer.
StumpChunkman 2 years ago
