Knex Chess Set
Intro: Knex Chess Set
This is a simple little chess set that I have come up with. The cool thing about this chess set is that the pieces don't just sit on the squares on the board, they actually clip in to it. Metallic and standard piece colors are needed to make this chess set usable. This could also be used as a checkers set, but everyone knows chess is so much better.
Everything is very easy to modify, especially the pieces. They are pretty basic, and if you build this you may want to improvise, make them larger, more colorful, etc. My brother suggested that I make a giant chess set and model each piece after a significant 'ibler, with Kiteman being the king, of course. That fell through. Anyway...
Enjoy!
Enjoy!
STEP 1: Piece List
For the board, you will need the following pieces.
Rods
Green - 272
White - 114
Red - 16
Connectors
Light Grey - 20
Green - 20
Yellow - 12
Purple - 64
Blue - 80
White - 16
For one set of players (you will need two of different color schemes):
Rods
Green - 44
White - 22
Connectors
Light Grey - 12
Red - 9
Green - 9
Yellow - 9
Purple - 16
Rods
Green - 272
White - 114
Red - 16
Connectors
Light Grey - 20
Green - 20
Yellow - 12
Purple - 64
Blue - 80
White - 16
Rods
Green - 44
White - 22
Connectors
Light Grey - 12
Red - 9
Green - 9
Yellow - 9
Purple - 16
STEP 2: The Top
This is a pretty sucky step. Get it over with.
Notice how the connectors are built in rows. It is important that you make your board identical. Remember the white and green rods on the sides!
1: Build it. Not too hard, just long and monotonous
2: Close up of the side
STEP 3: Sides
These are the sides when put together they will make a frame for the board and bottom to connect to.
1: Build this end piece. Nothing special
2: This is what the ends look like
3: Look from the top
4: Now build another one. You'll need one for both ends
5: Build these two side panels. Nothing hard either, just build what you see.
6: Close up of one end. The other side is identical
STEP 4: Base
This is the shortest step!
(applauding)
1: Build this big panel. Real easy. Don't forget the rods on the ends.
(applauding)
STEP 5: Assembley
Here you get to put the board together. Pretty easy. Go nuts!
1: Connect the two side pieces to one of the end bits
2: Should look like so
3: Add the other end bit on the other side. Now you have a box
4: Put the bottom piece in like so
5: Close up of that connection
6: Now, slap the board on top. Make sure that all the blues are pointing their slots either always at a 45 degree angle up or down. They cannot be side up, then down. then up, etc. Just make sure to put it on as it is in the photo.
7: Close up of one of the corners
STEP 6: Playing Pieces
These are the pieces that you will use. I strongly suggest that you modify them to your own taste however, these are just a suggestion. Just remember to keep the piece colors different for each team.
1: Pawns, each team needs eight.
2: Rooks, each team needs two.
3: Knights, each team needs two.
4: Bishops, each team needs two.
5: Queens, each team needs one.
6: Kings, each team needs one.
7: All in all, these are all the pieces that you need.
STEP 7: Go Play Chess!
You're done! Now you can play chess on your very own Knex chess set. Just a hint with clipping the players into place, you can either tilt the player and jam it in (photo two) or you can clip it onto the white rod, tilt it, and then unsnap it from the rod and clip it into place (photos 3-5).
Just in case you just got brainwashed, here are the rules to playing Chess.
http://en.wikipedia.org/wiki/Rules_of_chess
Thats all! Thanks for viewing my Instructable.
IaC
IaC
165 Comments
random_builder 7 years ago
I love the idea but it would be hard to tell apart
TheRoyalJester 11 years ago
KnexFreek 13 years ago
I_am_Canadian 13 years ago
ThisChessPlayer 14 years ago
JMan5 14 years ago
dungeon runner 13 years ago
barfingdog 13 years ago
Scizor 13 years ago
king of knex 13 years ago
Miles Tails Prower 13 years ago
The_Lost_Carrot 14 years ago
I_am_Canadian 14 years ago
imthatguy1125 13 years ago
harmenator 14 years ago
I made the black squares have one diagonal grey in it and you can Identify your own pieces by checking if the top rod is red or grey. I demolished it because I didn't know of instructables that time, and I played once with it.
I lost.
~Aeronous~ 14 years ago
LoL JK xD
Dirtyboyy 14 years ago
