Knex OMEN XR
Intro: Knex OMEN XR
Yes, I ripped off yet another gun name from goldeneye.
This gun was made in about a week when I saw DGM's attempt at a single shot. I decided to make my own bland and uninnovative single shot since there was some stuff from the rectangle that I didn't really like off the bat. I then built this so I could make a single shot that would fit my agenda for a good gun.
One of Oblivitus's comments when he was a mentor to me then struck me, and I decided to borrow parts off of other guns and combine them to make a single shot that would work for me better than others. Innovation was not a priority here, but I have made a new ammo storage container that can hold 6 red rods; it is located on the bottom.
Anyways, here is pros/cons
Pros
Note- DO NOT substitute any parts here.
Go to step 9 to view a major update with the gun.
Pros
- very comfortable
- true trigger
- powerful due to the singleshot
- 60-70 feet with the bands pictured, can shoot in the 80's with #64's
- lightweight (I can hold it in one hand, but it is recommended you use 2 so that you can aim easier
- comes with 2 foregrips
- Brand new ammo holder (holds 6 yellow or red rods)
- looks cool
- nothing too new, other than the ammo holder. I am sure you guys dont care because the Rectangle was not new, and you guys still liked it.
- low ROF due to singleshot/
STEP 1: Stock
This is the stock. Very comfy. Partial credit goes to dutchj for the idea, I did not build his comfort stock part by part, I just used his concept.
1- overview
2- view of the front
3- view of the rear
4- build these 2 parts
5- add the orange part to the stock
6- Add the other part to the blue connector
7- build the firing pin (this early? Yeah.) Remember the tape!
1- overview
3- view of the rear
STEP 2: Handle
I borrowed this off of Jollex's handle. Fill up the indicated white rods with spacers, and I only put knobs there since I don't have black wheels. Replace the knobs with black wheels please.
1- The handle. Build it
2- Add this part
3- connected
4- connect handle to stock.
5- Make the trigger. Put tape on the blocker part
6- add the trigger.
7- add knex knobs to the indicated rods. I took this picture later on because I forgot the first time.
Move on.
2- Add this part
3- connected
6- add the trigger.
Move on.
STEP 3: Bottom Part/ammo Holder
Its the new ammo holder!
1- Build these panels. Build it EXACTLY like its pictured. One has everything, the other has nothing
2- Build this. This is the second foregrip, and the bottom of the ammo storage container.
3- add it to the one with all the stuff on it.
4- Put the other panel on.
5- Connect to handle. Sorry for blur
6- closeup.
7- Make this. Fill it up with orange connectors. I did not fill it up because I ran out of connectors.
8- Add it to the gun.
6- closeup.
STEP 4: Barrel
This is Dsman 196276's barrel with mods.
1- Build this. This is the trigger housing.
2- The main barrel.
3- view from the top.
4- Connect the 2 parts.
5- Make this. This is the bottom support and the first foregrip.
6- Add it to the gun.
7- Make this. You should fill it up with oranges, but I ran out.
8- Connect one side to the gun.
2- The main barrel.
STEP 5: Connect Barrel to Gun.
I dunno why I made this a separate step, but whatever.
1- Connect pin guide to the barrel, and slide the pin into the barrel.
2- Connect the barrel to the stock. Stick the trigger up in the barrel.
3- Connect the front to the second foregrip.
STEP 6: Rubberbands/holding
Add rubberbands to the gun.
1- Add the bands to the trigger
2- Main bands. The ones I put on will get 65-70 feet, #64's will get in the 80's
3- How I hold the gun.
STEP 7: Loading and Firing.
Note that I have changed the name and did not bother to change the video to match this.
HAVE FUN!
Reasons this is better than the DD-27:
HAVE FUN!
- That tan lock in his barrel is not in my gun, so there is less friction
- better stock
- cleaner look
- better trigger
- Easier to pull the pin back.
STEP 8: Credits
Well, I can't really finish this ible without giving credit.
Oodalumps/DGM- inspiration to make this gun
Dutchj- Stock butt (the idea of it, I did not make an exact replica)
Jollex- main handle
Dsman195276- barrel
Back to how much I rule
Jollex- main handle
Dsman195276- barrel
STEP 9: MAJOR UPDATE- Rifled Barrel.
CJ81499 was shooting canadianammo (Red connector, yellow rod) out of my OSSR, and he managed to get the bullet spinning as if it was rifled. I took a good look at his video, and even though you can't see the round because it shoots so fast, I believe him.
The reason why I believe him is because the red/gray connector is catching on the white rods on the barrel in such a way that it has to turn when it leaves the barrel. This should makes it spin.
A video about how he puts the ammo in the gun: (Skip to 0:52 to see it, the rest is just random BS)
309 Comments
~KnexBuild~ 12 years ago
kylebusch18 12 years ago
~Aeronous~ 13 years ago
DJ Radio 13 years ago
lowe 13 years ago
beanieostrich 13 years ago
Furloy 13 years ago
sukinmaru 13 years ago
WalkableBuffalo 13 years ago
kylebusch18 13 years ago
amtdude 14 years ago
