Knex RBG: Plasma Pistol
Intro: Knex RBG: Plasma Pistol
A Knex repeater RBG, resembling the Halo Plasma Pistol.
Plasma Rifle
Pros:
-Semiautomatic
-Comfortable
-Looks and fires like the Halo Plasma Pistol
-Small and light. Hide it in a hollowed out textbook :D
Cons:
-Not really semi-auto since it may occasionally fire a burst of two rubber bands, even if the trigger is pulled once.
-Uses a modified piece.
Suggested use: Primary/ Secondary RBG
Similarities and differences between Plasma Pistol (according to Halopedia)
-Both may not fire projectiles when low on ammunition (this one may not fire if the rubber bands are too long, or not enough are loaded).
-Both are semi automatic
-Both have a similar shape.
-Accuracy is similar.
-Does not home in on a target.
-Half the length and height of the real plasma pistol.
-Only holds about 10 projectiles, not 200 (If you think of this as shooting overcharged bolts, this is a similarity)
-Both have the potential to stun (when aimed at the face for this one)
Plasma Rifle
Pros:
-Semiautomatic
-Comfortable
Cons:
STEP 1: Pieces Required
Rods:
6 green
15 white
blue
yellow
Connectors:
7 dark grey
5 red
17 green
11 yellow
1 white
2 orange
*If you have spacers, you will only need 3 dark grey and 13 white
6 green
15 white
blue
yellow
Connectors:
7 dark grey
5 red
17 green
11 yellow
1 white
2 orange
STEP 2: Special Peices
If you have connectors,
STEP 3: Barrel
Assemble the following according to the pictures.
STEP 4: Handle
STEP 5: Fore-grip
Not necessary for firing, but make it will look more like the Halo Plasma Pistol.
STEP 6: Firing Mecanism
STEP 7: Assembly
Attach fore-grip to barrel, and handle to firing mechanism. Then attach barrel and fore-grip to handle and firing mechanism.
STEP 8: DONE!
Here is a video of how to reload and fire. Since I only have two hands, I used a chair to hold the pistol. Also, I used rubber bands that are too long, so the trigger has to be reset manualy by pushing it forward.
STEP 9: Overheat Lid
Not necessary, but makes it even cooler!
Based upon SonicX 22's mod
48 Comments
Fr-Pa-Co 13 years ago
charge11595 13 years ago
K1TK4T 117 13 years ago
stormystormy 2 years ago
PartMan7 6 years ago
Awesome!
goffymew56 13 years ago
charge11595 12 years ago
dursa 13 years ago
knexsuperbuilderfreak 13 years ago
tayatipoop 13 years ago
thehaydn 13 years ago
knexinglemon 13 years ago
DutchxGuy 13 years ago
Spycrab 13 years ago
