LED CAR SIGNAL LIGHTS
Intro: LED CAR SIGNAL LIGHTS
after removing original front signal lights
check how much leds you can fit inside (you can use 12v leds in paralel or 2v leds in series)
for 12v leds you can have any number of leds
for 2v leds you ned to have an multiple of 7 (to be shure that you dont blow them)
this is how the finished light looks
original light was 21W bulb
now i have 7 LEDs 0.6W
this is ideal for an electric car
follow my electric car project here
http://ecomodder.com/forum/showthread.php/kadet-e-gt-ev-conversion-10655-3.html#post145992
STEP 1: Cutting Circuit to Size
you can use any non conductive material as support for leds (plastic)
i have used electrical test board cut to my size
STEP 2: Adding LEDS
after you have the circuit cut you can begin filling LEDS to it
use as much space as you can beacuse you need maximum light
test to fit inside before making electrical connections
BE CAREFULL FOR POLARITY
STEP 3: Finished LED BOARD
if everything is ok
wire the leds and couple it to an 12dc alimentator
it should lit
check if there is any unlit led (or leds)
it can be blown or is in oposite polarity (you need to reposition it)
you can mount the tail ight on car
it should lit
8 Comments
BobyF 9 years ago
Haha that flasher must be going craaazy.
yo man 13 years ago
gman2000watts 14 years ago
jerpelea 14 years ago
i have used 12V leds
PedroDaGr8 14 years ago
If these are sold as 12V LEDs, then they likely already have a small resistor soldered in already. THat being said, you NEVER NEVER NEVER specify a cars voltage system as 12V. Unless you want your LEDs to die. Car voltages fluctuate usually between 11-12 point something under load and 14 point something while charging. Let alone, there are often voltage transients that can get up into the 16-20V range (cars are electrically VERY noisy, as relays click on and off, compressors and pumps engage etc.)
Now you could EASILY get around this by using a simple LDO 12V regulator.
If done properly, the regulator will filter out all of the spikes and other nasties and provide a nice clean 12V source. Keeping your LEDs nice and happy.
Also I want to see pics of your turn signal in bright sunlight. I get the feeling it will washout (amber LEDs for some reason are the WORST at this).
i will post the pictures for sigan lights but now is snowing so no sun :(
l8nite 14 years ago
