LED Lamp From Lighters
Intro: LED Lamp From Lighters
This time I will show you, how to make a simple LED lamp from lighters.
How I did it - you can check by looking DIY video or you can follow up instructions bellow.
Attention: the best and recommended way is to use empty lighters, because gas inside is flammable. Light source mus generate heat little as possible. If you will use lighters with gas inside - take it on your own risk. Some from non will be not responsible for any possible consequence. Good luck!
For this project you will need:
Materials:
12V LED strip ~25cm
12v 1A power supply
32 lighters
small piece of plywood
small aluminum can
On/Off switch
Tools:
Hot glue gun + hot glue
Soldering iron
Cutters
STEP 1: Begining..
Started from glueing 7 lighters in a row side by side. Used hot transparent glue.
In this way made 4 identical pieces.
STEP 2: Side by Side
Connected two pieces and secured with hot glue. Later on, third and fourth sides.
STEP 3: Installing LED
Took Redbull drink can and a 12V LED strip. First twisted LED strip in needed pattern and after that pulled off protecting tape and sticked strip to the can.
STEP 4: Power Supply and Switch
To power LED strip used 12V 1A power supply. Cut off old connector, striped wires and soldered one wire to LED strip. At other terminal soldered spare wire which will be connected to on/off switch.
STEP 5: Placing Switch
Took out some guts from one lighter, filled with hot glue and sticked on/off switch inside.
STEP 6: Finishing Bottom
For lamp bottom used a piece of plywood. With hot glue glued can to the plywood.
Inserted can to lamp and glued last lighter with switch. After that glued plywood bottom.
STEP 7: Finishing Top
To close the top used 4 lighters and with hot glue set them in place.
STEP 8: Result
That’s how looks finished LED lamp from lighters. On/Off button is easy accessible and almost not visible.
I’m very happy how it came out. Gives nice, colored light.
13 Comments
Lisa Ander 6 years ago
DerekM114 6 years ago
Dardo A.E.P 7 years ago
dangerous! use empty lighters!
maniacse 7 years ago
Absolute perfect idea! Thank You for sharing!
MarceloG19 7 years ago
Such a cute object! Pity that it's quite flammable!
tina.gallagher.125 7 years ago
I'd give a little more detail such as the size of the wiring and adapter and switch. Second, include a warning not to use an incandescent light because the butane could ignite. Other than those two things, this is a wonderful project. I'd use empty lighters just for the safety. This is a great way to recycle otherwise disposable items.
Yonatan24 7 years ago
If those are new, I really, REALLY, REALLYREALLY hope that no-one uses an incandescent lamp.
Just a warning for other people, but other than that it looks pretty cool :)
sabu.dawdy 7 years ago
amazing project
4DIYers 7 years ago
Awesome work, great was to reuse old lighters!
Pra_ga 7 years ago
Dude! This is awesome!!
I love the way it casts the colorful light!
mtairymd 7 years ago
Awesome design. I like the multi-color look.
mrsmerwin 7 years ago
I don't have the lighters but I have got a lot of old power cords that we no longer have the device. I am pleased to see how easy it is to put them to use. Thanks.
DIY Hacks and How Tos 7 years ago
That looks really cool. I like the effect that you get with multiple color lighters.
