Large Dining Table
Intro: Large Dining Table
I've always wanted a big and robust dining table, but they cost a fortune. So why not build my own?
It really isn't that difficult and took me about three days to complete.
This does not give you a very thorough description of how to make the table, but it will give you a rough idea of what it can look like.
I wanted to make a table made completley out of wood, so no nails or screws are used.
It's important to get thick enough and straight planks. The better material, the better your table will be.
I like to do things from scratch so I went out and got some logs in our forest and took them to the local sawmill.
STEP 1: Preparing the Planks
Now it's time for the tedious but rather meditative planing, grinding and milling.
The easiest option is to buy prepared planks but if you have the tools it doesn't take that long.
STEP 2: The Tabletop Is Starting to Form
Cut the logs in the exact same length and round off the edges with a wood shaper.
Cut the transverse plank in a classy shape and grind it to a smooth surface and round off the edges.
STEP 3: Working on the Trestle
It's easiest to make the cross in a 90 degree angle, you don't have to think as much if you do that.
Meassure the height that you want of the table and put the legs over eachother with a 90 degree angle to eachother. Dont forgett to count the thickness of the table top in to the entire height of the table.
After you have marked it, use an angle iron just to make sure its exactly 90 degrees. Use a saw and a chisel to make the two peaces fit.
Cut the two ends in a 45 degree angle and fit the two legs together with wood glue.
Now it's time for the plank between the two crosses. Meassure the length that you want between the crosses and make the plank long enough to go through the cross and stick out a little longer.
Make a squared whole in the center of the cross for the plank to go through. Use the saw to cut the edges of the plank to fit the hole. Now all you need is a small piece of wood to go through the plank to lock it in place. Make it tight so that the whole trestle is stable.
STEP 4: A Check Before the Assemble
I put the table inside the house to see how it was matching with my sofa. Some of the planks were a little oblique so I had to try to strighten them. The straightest thing I could find was two ladders which I attached with all the clamps I could find and left it for a month and a half.
STEP 5: Adding the Woodstain
To protect the wood and to get a matching colour I used oak woodstain. The wood texture really comes out.
For extra protection, use lacquer. This prevents the wood from absorbing any liquids that may get spilled on it in the future.
STEP 6: And the Table Is Completed
To attach the tabletop to the legs, use a round wodden rod. Drill a hole for it and stick it through the legs and transverse plank. Make sure it's tight.
21 Comments
joshsmithm 8 years ago
Hi, Your idea is great! You can also get more awesome plans from - http://rogueengineer.com/diy-farmhouse-dining-table-plans/
patticake1601 10 years ago
explosivemaker 10 years ago
danzo321 10 years ago
ar_caver 10 years ago
Scott Elkington 10 years ago
Ricardo Furioso 10 years ago
The c is actually pronounced like ch as in children.
You can be proud that you have built something magnificenza
for your great great grandchildren to tell stories around.
Bravo.
Bravissimo.
As for tools, I don't see anything that couldn't be done with basic, non-powered handtools that I've seen at numerous yard sales, flea markets and antique stores. Just in the last week I've seen every saw, chisel, plane, mallet, brace and bit needed for a project like this. Lots of good tutorials out there on how to tune up an old hand plane and other tools. With a table that may last centuries what difference does it make if it takes six months or two years to build?
thebeatonpath 10 years ago
BimboKay 10 years ago
chuckyd 10 years ago
1) Wet glasses and other wet implements will leave rings in the laquer finish. To get rid of the rings you will need to refinish the table. A more durable finish is three coats of satin polyurethane. That finished survived three kids and gallons of red Kool-Aid for 12 years.
2) To allow for thermal and moisture movement of the top planks, the top should NOT be tight to the cross pieces. The cross pieces should have elongated holes to allow the wood planks to swell and shrink across their width. If you don't want to use metal screws you could make a dowel shaped somewhat like a rivet.
Great design, though.
rdrosd 10 years ago
herquiltness 10 years ago
DIYfan 10 years ago
molarin 10 years ago
I wanted to build a table without nails or screws as a challenge. I attached the table top planks with wood dowels and glue.
dtousey 10 years ago
I had no intention of publishing this when I built the table but when I found this website I thought it could be worth sharing so I uploaded the photos that I had. It always helps someone. The photos from the sawmill were just for fun.
I bought the candle holders from a friend, unfortunately I'm not sure where they came from.
phish814 10 years ago
paolobertoncin 10 years ago
