Laser Etching Macintosh Powerbooks.
Intro: Laser Etching Macintosh Powerbooks.
The appropriate files, laser settings, and methodology for putting your tattoo on your powerbook.
as this was boing boing ed a few weeks back i thought i'd show how it is done...
STEP 1: Select Your Artwork.
any bmp, jpg, tif, dxf will do. basically any vector or pixel (bitmap) based artwork. the higher res you can do the better. i like vector because it is scale independent.
STEP 2: Lay Out Artwork in Template File.
You can find here the template files (illustrator CS and illustrator 8 versions) where you can lay out your own artwork. stay out of the apple and the red zones and you will be safe. the apple is plastic (don't laser here) and the red border is the radius at edge of laptop.
You can see here the example of my kite file (dxf original) overlayed to fill fully the page and look a little like an engineer's drawing spec...
STEP 3: Determine Raster / Vector Style of Work.
the wave is a cool tif or rasterable image. this means the laser treats pixels as pixels and goes side to side as it builds the image.
the kite is vector meaning the laser follows the path of each individual line and therefore much finer detail can be produced.
STEP 4: Set Laser Speeds and Feeds Appropriately.
I use an epilog mini: http://www.epiloglaser.com/mini24_overview.htm
the nice result setting is 50%speed, 100%power for a bitmap image, 20%speed, 100% power for a vector image.
STEP 5: Run and Enjoy.
the end.
78 Comments
jarrod.pretorius.16 9 years ago
Can you put a picture on the back of an IPad mini2? I heard it's called Laser etching but I'm not sure if it's actually doable?!!! This is the image I want on the back of my IPad!
TomDG 7 years ago
It's theoretically possible. The way I do it I convert images in Illustrator using the Image Trace function under the Object Menu. It creates a vector out of an image and converts it to black and white. There are other options for Image Trace but they wouldn't work with the lasers I've used since they only recognize a few different colors and each one has to be mapped to a certain function of the laser. Once you have finished your Image Trace to your liking you can resize it without any loss in detail (Yay, vectors!). Resize it to fit on the back of your iPad Mini 2 and position / rotate it as necessary. Once you've done that then you're pretty much good to go. Just enter in the settings for the laser, get everything in focus, and engrave away. I know this is 2 years old now, but I figured it might be helpful for others who come across it.
lahren1 9 years ago
Does anyone how much power and speed I should use for a Epilog or Trotec laser etcher?
lahren1 9 years ago
I think it's a Helix model
Fog 17 years ago
tewmten 17 years ago
Tableleg 17 years ago
thepelton 14 years ago
Mindmapper1 11 years ago
Thundertydus 15 years ago
jeshaw3242 15 years ago
jongscx 17 years ago
Derin 15 years ago
tailortrik 14 years ago
My school requires a MSDS (material Safety data sheet) for using any new material with the Laser cutter.
I am trying to figure out what kind of aluminum they use and just find manufacture and a sheet for that.. Any hints?
ste3ve 17 years ago
sbaumgarten1 12 years ago
mpandersen 13 years ago
1) Will the Class 3B laser enclosed within the XBox DVD-ROM drive have sufficient power to etch commonly available materials ?
2) What is the Milli-Wattage of this laser ?
3) What is the Wave-Length of this laser ?
4) Since I like looking at my surroundings, what class of Safety Glasses should I purchase. Are there any other pertainent issues I've overlooked ?
Thanks, Mark
P.S. : I'm conducting this experiment under strictly controlled conditions :
Door Locked (I have the only key !!!), and with No Visitors, No Phone, and ZERO Distractions. As I'm in my forties, I have learned a few things in my life, like I only have ONE, and I LIKE it !!!
smcorson 16 years ago
CamWaite 14 years ago
