Leather Wine Rack
Intro: Leather Wine Rack
Project Summary: Let’s make a simple, but beautiful wine rack with an English Bridle leather. We’ll cut a pattern, mark, cut and edge our leather and assemble a clean wine rack with ample room for decoration.
Approximate Time to Complete: 2 Hours
What You Need:
· English Bridle Leather, Rich Brown appx. 2 sq. ft. (15-971)
· Jeremiah Watt Dee Rings (04125-SS-2)
· 6 Chicago Screws, 1/4" (D5038-NB-1/4)
· 8 Chicago Screws, 3/8" (D5038-NB-3/8)
· Medium Brown Lace, 1 foot (30-1837-MB)
· Utility Knife (65-2860)
· Awl (CSO4-2)
· Steel Square (65-3038)
· Rawhide Mallet (65-2520-11)
· English Point End Punch (00078-2)
· Drive Punch (CSO245-6)
· Cutting Board (65-2916)
· Tooling Slab (65800-)
· Strap Cutter (65-6261)
· Groover (8069)
· Edge Beveler, #2 Blade (65-2988)
· Gum Tragacanth (50-2075)
· Wool Daubers (50-1950)
· Leather Slicker (65-2962)
· Fiebing’s Leathercrafter’s Cement (50-2124)
STEP 1: Draw Your Pattern
Take a 23” x 6” piece of paper and fold length wise and width wise. This will give us a vertical (long/23”) and horizontal (width/6”) center line. Draw in these lines with a pen or pencil.
STEP 2: Continue Drawing Pattern
From the horizontal center line measure 4½” to the left and draw a line across the width of the pattern and 4½” to the right of the center line and draw a line across the width of the pattern. This should give us 3 horizontal lines 6” long and 4½” apart.
STEP 3: Mark Loop Rivet Holes
Make a mark 3/8” in from the edge of the pattern on the left and right side of each of these three lines and circle that mark. These will be our “loop rivet holes”.
STEP 4: Mark Corkscrew Placement
On the vertical center line, measure and make a mark 2” from either outside horizontal line (for corkscrew placement) and this will determine the “top” or “up” on the wine rack/pattern. On a horizontal line from that mark measure 3/8” to the right and mark, then to the 3/8” to the left and mark. These two marks will be for the corkscrew loop. Circle these.
STEP 5: Mark Billet Punch Holes
For the billet punch holes, draw a line 3/8” in from the top edge of the pattern and make a mark 5/8” to the right and 5/8” to the left of the vertical center line and circle.
STEP 6: Mark Last Billet Hole Punch
For the last billet punch hole, make a mark on the vertical center line 7/8” from the top of the pattern and circle.
STEP 7: Fold Pattern and Mark Opposite Side
You can fold the pattern over lengthwise and, using and awl, mark the billet holes on the other end or simply repeat #5 and #6 for the “bottom” of the Wine Rack. Circle these holes.
STEP 8: Draw Tapered Part of Pattern
To mark the tapered cut on the pattern, draw a curved line (freehand or with a French Curve) from the edge of the pattern where the horizontal corkscrew line meets the edge (5” below top of pattern) to a point 1” to the left or right (depending on your fold) of the vertical center line. This will be the same mark as the edge of the billet (2” in from edge of pattern).
STEP 9: Cut Pattern
With the paper folded lengthwise and width wise cut the curved line. By folding the paper down to one quarter we make one cut and all four sides are symmetrical.
STEP 10: Mark Rivet Holes
For the wine bottle loops, cut your pattern paper to 6” x 10” and draw a line 3/8” in from all four sides. Circle each line intersection at the four corners. These will be the rivet holes to connect to the main body
STEP 11: Cut Corkscrew Loop Pattern
For the cork screw loop, cut a piece of pattern paper at 1 ½” x 4” (this can vary to accommodate your corkscrew choice) and draw lines 3/8” in from all four edges. Draw in the center line width wise (1 ½” width) and mark each intersection. This should leave you with six circled holes. The four outside holes will be for lace and the two inside holes will secure the loop to the wine rack.
STEP 12: Cut Billet Pattern
For the billets, cut a piece of pattern paper 2” x 5 ½”, fold width wise and length wise, draw a line 3/8” in from all four edges and draw in the length and width center lines
STEP 13: Mark Intersection
On the length wise center line, mark the intersection of the 3/8” line and circle.
STEP 14: Mark Intersection #2
From this mark measure ½” down the center line/away from the edge and draw a line across the width. Mark the intersection with the 3/8” line on both sides and circle all three marks.
STEP 15: Mark Opposite Side of Pattern
Fold the pattern paper lengthwise and mark the three holes on the other end of the pattern.
STEP 16: Transfer Pattern to Leather
Transfer the patterns to your leather and scribe for cutting.
STEP 17: Cut Leather
Using a utility knife or round knife and a straight edge, cut out 1 main body piece, 2 wine bottle loops, 1 corkscrew loop and 2 billets.
STEP 18: Punch the Ends of the Billet Pieces
Using a 2” Round End Punch, punch the ends of the billet pieces to round the corners.
STEP 19: Punch Holes
With a Drive Punch, punch the circled holes with a 3/16, or slightly large, punch tube on all pieces
STEP 20: Groove Lines on Leather Pieces
Using a Stitching Groover, groove a line 1/8” from the edge on all sides of each leather piece.
STEP 21: Edge Leather Pieces Front and Back
Using a #2 Edger, edge all sides of each leather piece front and back.
STEP 22: Burnish Edges
With a dauber, add a light coat of Gum Tragacanth to all edges of each leather piece and burnish.
STEP 23: Assemble Pieces
To assemble the Wine Rack, start with the main body lying flat with the top of the Wine Rack to your left.
STEP 24: Add Chicago Screws
Take one of the wine bottle loops and lay it face down with the 6” sides to the left and right. Put the female side of two ¼” Chicago Screws into the two punched holes on the left of the wine bottle loop.
STEP 25: Position Screws
Position these two screws over the two punched holes on the lowest of the three sets of “loop rivet holes” on the main body. You’ll notice the main part of the loop goes away from the top. This is correct.
STEP 26: Secure Screws
Add a small dab of white leather craft cement (or white glue) and secure the screws.
STEP 27: Add Second Wine Bottle Loop
Take the second wine bottle loop and again, lay it flat with the 6” sides to the left and right and put the female part of two 3/8” Chicago Screws into the two holes on the left side of the loop.
STEP 28: Position Holes
Fold the first loop towards the top of the wine rack (top grain is now out) and position the other two punched holes over the middle two “loop rivet holes”.
STEP 29: Position Chicago Screws
Take the second loop and position the Chicago Screws over the first loop rivet holes and the corresponding main body “loop rivet holes”. Two notes: The main part of the wine bottle loop will, again, be away from the top and you will be going through three layers. The top of the first loop, the bottom of the second (or higher) loop and the main body.
STEP 30: Secure Screws
Add a dab of glue to these two crews and secure.
STEP 31: Complete Wine Bottle Loops
Fold the upper wine bottle loop towards the top of the wine rack, same as the first, and secure it with two ¼” Chicago Screws (add a dab of glue). This should complete the wine bottle loops.
STEP 32: Position and Secure Screws
Take the corkscrew loop and lay it face down with the 4” sides to the left and right. Put the female part of two ¼” Chicago Screws in the two punched holes in the center and position to correspond with the two corkscrew loop holes on the main body. Secure the screws with a dab of glue.
STEP 33: Secure Billets
To secure the billets start with either end and drop the female part of three 3/8” Chicago Screws into the punched holes on one end or the other.
STEP 34: Add D-Ring
Add a 2” D-ring and bend the billet around the end of the Wine Rack and secure the three Chicago Screws with a dab of glue.
STEP 35: Repeat on Opposite Side
Repeat the previous step for the opposite end.
STEP 36: Add Lace
To close the corkscrew loop with lace, take a piece of lace approx. 14” long and come from the inside out of both holes on one side of the corkscrew loop. Crisscross the two strands of lace and enter the two lace holes on the opposite side by going from the outside in.
STEP 37: Tie a Knot
Tie a square knot, or something close, on the inside of the loop. The corkscrew loop carries almost no weight, so, a strong knot isn’t necessary.
STEP 38: Project Complete
Add a corkscrew and two bottles of wine and your project is complete!
alloydog 6 years ago
Neat idea. But, you know, if you made it longer, with more hoops for the bottles and made the hoops into cups, you could make a Wine Bandoleer...
