Lighter USB Flash Drive
Intro: Lighter USB Flash Drive
a fun half hour project that give a pleasing result.
you'll need:
An empty lighter (I used bic mini as I had a thumbdrive for this)
A large nail (brute force is needed at times)
A saw (hacksaw's good)
a dremel or sanding block etc (smoothing edges)
you'll need:
STEP 1: Knock the Ends Off
First take your saw and cut just on the line of the join between the body and the whit end cap, one this is cut off you may need pliers to pull bits of it out. Once the bottoms off you need a screwdriver or anything slim but strong enough the shove into the cavity and break the plastic bits of the inside off (creates more room)
After this pry off the metal part of the top and you'll see that the flint wheel is held between 2 plastic legs, push these apart to pop the wheel off and expose the flint tube, a spring and little stone like cylinder should have fallen out. Now take your nail and slide it all the way into the tube. Hit the nail with a hard blunt object, a hammer's good but not necessary. Shake out all the plastic that's now broken off.
STEP 2: Insert the Usb Part
You'll need to take you drives cover off and then use half of it as the circuit holder (called recycling, not to mention common sense) now using a knife whittle away parts of the end of your holder while intermittently checking how well it fits, it should be quit tight and not easy to pull out, however it should fit int all the all until circuit are covered completely.
I used a 2GB datatraveller
I know it's a quick and dirty case mod but it looks cool and should take 15 mins to half an hour.
Make sure your lighter is empty as there is no way I'm claiming liability for someone that dumb...
81 Comments
neozelandes 12 years ago
i dont know how to add photo's to the comment
NeonLime 16 years ago
8bitRaven 13 years ago
Hycro 13 years ago
killerjackalope 16 years ago
looking4ideas 15 years ago
killerjackalope 15 years ago
Xellers 16 years ago
iamthemargerineman 16 years ago
akunk 14 years ago
they look idenrtical
jo jo 15 years ago
cry_wolf 15 years ago
AnarchistAsian 15 years ago
thoraxe 14 years ago
AnarchistAsian 14 years ago
JettyMae 15 years ago
