Linear Actuator in 5 Minutes
Intro: Linear Actuator in 5 Minutes
Always wanted the linear motion but were stuck with the circular motion of the motor .You have landed on the correct place
STEP 1: Supplies Needed
List of the material you need is
- a power drill
- a flat file
- tape
- a bolt (of about 75 mm length)
- 3 nuts of that size
- motor
- wire cutter
- a coupler used in tube lights
STEP 2: Making the Shaft
Take the bolt fix it in the drill machine and stick the file flat with help of a tape
STEP 3: Coupler
take the coupler remove its plastic shaeth and arrange them
STEP 4: Piece for Movement
take the 3 nuts and screw them on the bolt such that the bolt is free to move . Now solder the 3 nuts together
STEP 5: Completed
On one polarity goes up and on other goes down
14 Comments
jwzumwalt 7 years ago
Would you please provide a link for the coupler. I do not recognize this as a electrical part for lights.
sanyam jain 7 years ago
You can find them on the following link
Thanks for the link. I suggest you update the description for this part, it has nothing to do with tube lights :)
piperjon 7 years ago
ElectroFrank 7 years ago
When the nut is fixed to something, the rotation of the screw thread converts the rotary motion into linear movement.
(Exactly the same as the fan belt adjuster on your car.)
it creates linear motion exact as the z axis of the 3d printer does when the nuts are fixed they will move up and down making a linear motion.If still not understood feel free to ask again :D happy to make
Joeybloos 7 years ago
when the bolts are held or added weight to they provide the motion.
yes this can be done but the problem is with the dc motors.no matter how hard you try there will be a gap in the movement of the motor so for that replace motors with the stepper motors
goacego 7 years ago
thank you :D
