Lolerskaters Homemade Nerf Darts (They Get Extreme Distance)
Intro: Lolerskaters Homemade Nerf Darts (They Get Extreme Distance)
These homemade Nerf darts rock!! they are made out of foam backer rod and get sweet distance. Trust me they are better than any others. They also fit any Nerf gun!!!!
STEP 1: Get the Stuff
For this project you will need:
1. some foam backer rod (the gray coil) its inexpensive!!
2. a couple of nerf bullets to measure
3. a philips screwdriver
4. a paint brush or some kinda small rod
5. scissors
6. lots of BB's
7. a nerf gun to test em out!!
5. scissors
6. lots of BB's
STEP 2: Cut Your Dart
Cut the dart from the coil of foam. use your regular dart as a reference.
STEP 3: Make the Hole
Use the screwdriver to make the dart hollow by shoving it trough the center of the dart(do not go trough the top of the dart, stop right before u poke trough it.
STEP 4: Insert Your BB Weights
Using the end of the paint brush insert 2 bbs (one at a time) in to the dart. Do so the same way you did with the screwdriver. push the bbs all the way to the top without busting it open.
STEP 5: Test It!!!
Load your dart into a nerf gun and FIRE!!!!!
STEP 6: Repeat!!!
Do this about 200 more times!!!!!!!
139 Comments
NerfFTW 7 years ago
you didn't invent this. Stefan, an early nerfhaven user, did. Give credit
snaglefang 15 years ago
SethM3 9 years ago
thats what the screwdriver hole is for
Shut Up Now 14 years ago
snaglefang 14 years ago
NatNoBrains 13 years ago
F
THECHINABOY 13 years ago
SethM3 9 years ago
yes i think so, but any bbs work
jake4a4 13 years ago
SethM3 9 years ago
Wow... your friends are wimps, but you can put a small dome of super glue at the tip. it works as padding and makes it go farther. you may not want to use 2 bbs though. 1 should work.
Pwag 12 years ago
Might leave more foam at the tip of the dart.
coolcam 14 years ago
curious youth 12 years ago
GEORGE41708 11 years ago
ThatKnottyguy 11 years ago
cksaint 16 years ago
Lostkid 16 years ago
nerfer192 16 years ago
