Low Cost Spirometer
Intro: Low Cost Spirometer
This is a project I completed for a biomedical instrumentation class at Vanderbilt University. This spirometer uses a pressure transducer and an Arduino Uno to compute the volume of air blown through the plastic tube. The circuitry is very basic- the majority of this project relies on the coding and an understanding of fluid dynamics. I'll go through the set up of the physical circuitry and then delve in deeper to the code and mathematics.
Spirometers are typically used in a clinical setting to diagnose pulmonary disease. These tools measure the amount of air expired, and in some cases, can show the change in flow rate over time. This simple, low cost spirometer allows for a rough calculation of the volume of air expired from the lungs over a period of time. A button on the Arduino LCD screen is used to control the period of time over which this calculation takes place. The results are clearly displayed on the LCD screen, making this a fun, easy to use device.
Although this device is not intended to be used in a clinical setting, it was interesting to learn about pressure sensors and Arduino applications while working on this project. I hope you enjoy!
Materials:
-PVC pipe
-Plastic tubing
-Glue
-Pressure sensor (see Step 2)
-Arduino Uno
-Arduino compatible LCD screen
-Computer
-Micro USB cable
-Breadboard
-Wires
STEP 1: Construct a Spirometer Tube
I was able to salvage my tube from a previous year's project, but I would recommend building your own spirometer tube in order to better customize the diameter size.
The tube should have two sections, one with a large diameter and one with a significantly smaller diameter. In my project I used D1 = 2.3 cm and D2 = 0.6 cm. PVC piping might be a good alternative to using a plastic tube. If I were to do this project again, I would definitely use tubes with a larger diameter difference. I ended up using duct tape in order to create a smaller diameter within the second half of the tube.
On each side of the diameter change, drill a small hole and connect plastic tubing. These two pieces of tubing will later be attached to the pressure sensor in order to calculate the pressure drop across this section of the tube. Make sure the seal is tight by using enough glue.
STEP 2: Select a Pressure Sensor
The only circuit component used for this project is a pressure sensor. I used a differential Honeywell ASDX Series Silicon Pressure Sensor. I liked using this sensor and I've attached the data sheet to this page.
Differential pressure sensors are able to convert a difference in two pressures to a voltage. A diaphragm is placed between two compartments of the sensor. Each compartment has a port where a pressure can be applied. When different pressures are applied to the two compartments, the diaphragm moves. The diaphragm is attached to a series of piezo-resistive strain gauges that are connected in a Wheatstone bridge configuration. As the resistances change, the output of the bridge circuit changes and can be used to calculate the pressure difference.
The sensor requires connections to a supply voltage (typically 5 V) and ground. There is also an output voltage pin, which is where the signal we are using will be produced. For this particular sensor, the output voltage when the pressure difference is zero is equal to 1/2 of the supply voltage. I used a 5 V supply, so my output was 2.5 V when there was no pressure differential applied. There is an equation included in the data sheet than can be used to calculate the pressure based on the output voltage.
STEP 3: Attach Arduino Microcontroller
Another major component of this device is an Arduino Uno microcontroller and a compatible LCD screen with buttons. They can be purchased here: http://www.arduino.cc/en/main/arduinoBoardUno. Connecting the Arduino to the pressure sensor is very simple. Since the Arduino is able to supply 5 V and ground, I was able to power the pressure sensor with the Arduino alone.
Before attaching wires from the pressure sensor to the Arduino, attach the LCD screen to the microcontroller. It should easily fit into pins of the Arduino. The pressure sensor can then be connected using the pins on the LCD screen.
My configuration was as follows:
Pressure Sensor --> Arduino
Pin 1 (supply) --> 5 V
Pin 2 (output) --> A1
Pin 3 (ground) --> GND
My pressure sensor was attached to a basic breadboard and the Arduino microcontroller was attached to a PC via a micro USB cable.
STEP 4: Creating the Code
This step was by far the most time intensive portion of this project. Luckily for you, I've done most of the work already! In this step, I will attempt to explain the fluid mechanics and the path I took to get from voltage to air volume using some relevant equations. I've also attached my Arduino code as a pdf document, so feel free to take a look at that and change parameters as necessary for your design.
1. Converting between digital and analog signals:
When an analog signal (like the voltage produced by our pressure sensor) is processed by the Arduino, it is converted to a digital value between 0 and 1023. Our first step in the code after reading in this value is to convert it back to an analog value. Here is the bit of code doing just that:
inputVolt = analogRead(analogInPin); // Voltage read in (0 to 1023)
volt = inputVolt*(vs/1023.0);
2. Converting from a voltage to pressure:
The purpose of the pressure transducer is to turn a pressure difference into a voltage, but now we want to determine the pressure difference based on a given voltage. The datasheet provides an equation to do just that, and with some rearranging, the pressure can be calculated as follows:
pressure_psi = (15/2)*(volt-2.492669); // Pressure in psi
You may notice that a value of 2.492669 is used instead of the 2.5 that I expected the sensor to produce at equilibrium. I determined this more precise value after a number of calibrations showed that my equilibrium value was not at exactly 2.5 V. You may need to adjust this number based on your own sensor's tendencies.
3. Psi to Pa
The equation given in the data sheet gives us the pressure in psi. In order to make further calculations easier, we will convert this to Pascals, which is the SI unit for pressure.
pressure_pa = pressure_psi*6894.75729; // Pressure in Pa
4. Calculating mass flow from pressure
This next step involves some fluid mechanics knowledge and creative algebra, but ultimately allows you to convert your pressure difference into a mass flow rate. The follow equation can be rearranged to solve for W, the mass flow rate in kg/s:
dP=((W^2)/2rho)*(1/A2^2−1/A1^2)
Where dP is the change in pressure across the tube in Pa, W is the mass flow rate in kg/s, rho is the density of air in kg/m^3, and A1 and A2 are the cross section areas of the two different sections of your tube in m^2. After rearranging and including values for rho, and the A1 and A2 for my specific tube design, I was able to compute W with the following code:
massFlow = 1000*sqrt((abs(pressure_pa)*2*rho)/((1/(pow(area_2,2)))-(1/(pow(area_1,2))))); // Mass flow of air
The syntax in Arduino makes this a bit messy, so be sure to check your parentheses. I also included a factor of 1000 so that in step 5, we end up with L/s instead of m^3/s, which allows the volume to be in a standard unit.
5. Mass flow to volumetric flow
This step is relatively easy- we can convert mass flow into volumetric flow by dividing by the density.
volFlow = massFlow/rho; // Volumetric flow of air
6. Computing volume
Finally, we have reached a point where volume can be computed. Since Arduino does not have the capability to perform integrals, we have to manually add up our volumetric flow rate over time. Since volumetric flow rate is simply volume over time, we can sum up the volumetric flow rate over small bits of time to compute total volume. This can be done using a delay in Arduino and multiplying each volumetric flow rate value by a small dt value.
volume = volFlow*dt + volume; // Total volume (essentially integrated over time)
dt = 0.001;
delay(1);
That's all the math! The rest of the code is just setting up the LCD screen, defining variables, and setting up the button controls.
The if statement in the code causes the volume to be calculated only when the button is being pushed. This feature prevents the calculation from being affected by noise, and also allows the user to indicate when air is actually flowing through the tube.
STEP 5: Try Out Your Spirometer!
Finally, you can try out your spirometer! In order to use the device, attach the tube created in Step 1 to the pressure sensor using the two pieces of tubing. Bring the tube up to your mouth and blow through it, while simultaneously pressing the up button on the LCD screen. Once you have finished expiring, release the button. The volume you expired will be neatly displayed on the LCD screen in liters.
I hope you enjoyed this instructable! Thanks for reading!
25 Comments
zainabsania02 2 years ago
abuhafss 6 years ago
Anup Handique j 2 years ago
abuhafss 2 years ago
I worked a bit on this project but later I dropped it. I don't remember where I stored my working but the theme was to use 2 sensors.
Eng-AhmedK 4 years ago
thank you.
meser67 3 years ago
nguyenthaihoang.mp1993 3 years ago
I use this data for my final project.
Kidder1_ 5 years ago
HarishP32 6 years ago
Errors on arudino software
no lcd
No button on verify result
Niraimathy 7 years ago
Awaiting your response... we would love to communicate to you through email as well please ping us at sakthigyanavel@gmail.com
Mohammad RezaH1 7 years ago
ashrafsy16 7 years ago
now i preparing for my project in my university and by search by google i found your work about spirometer but i have some of confuse about this project
i used pressure sensor with 2 input and max pressure 500 kpa
and by arduino i will calculate the volumes and air flow
please help me how i will choose a pipe ?
CadisEtramaDiRaizel 7 years ago
Can you explain how you used the following formula in the code?
How did you get 15/2?
Pierpa_76 7 years ago
The pins are identical ARDUINO based on version 3 as well ? I bought the complete form and thanks to this project I want to try for the first time Arduino . Hello and thanks.
LucaR18 8 years ago
I am very interested to your project because I am a free diver an I would like to measure the pulmonary capacity variation with different kind of breath techniques.
Which sensor p/n did you used? How is precise? Thanks! ;)
SurduM 8 years ago
Hi MariaL7! Congrats for your project!I have a question and i will thank you very much if you can let me an answer.Can you show me a model of that tube? I push the air in that tube and i see the air is going to sensor on .The sensor have an out for the air? Thanks for your time !
CameronH21 8 years ago
GraceW3 8 years ago
Hi:) I'm doing a class project and my group and I were really interested in your design. We are slightly confused about the interior of the pipe, can you possibly post more photos or email them to me? (email: gwhang@ucsd.edu) Thank you :) Neat project by the way!
emason 9 years ago
I can't agree more that the 2nd / 3rd world needs cheap medical tech.
