Magical Wand That Lights Up!
Intro: Magical Wand That Lights Up!
This is a (Harry Potteresque) wand that can cast 4 different colored spells. I chose red (Stupify ), white (Lumos ), blue(Expecto Patronum ), and green (Avada Kedavra ).
Each spell is commanded by a tact switch at the base of the wand. The wand can be customized to your style and spells.
STEP 1: Materials
Materials
electrical tape
1 wide wooden dowel rod
1 CR2032 battery
1 CR2032 battery holder/clip
1 toilet tuber
1 green LED, 3-2.3VDC (The lower VDC creates a more intense glow), 5mm
1 red LED, 3-2.3VDC, 5mm
1 blue LED, 3-2.3VDC, 5mm
1 white LED, 3-2.3VDC, 5mm
WiringSolder
4 Tact switches, 5mm
electrical tape
1 CR2032 battery
1 toilet tuber
WiringSolder
STEP 2: Cutting the Handle
Taking the dowel rod, you are going to cut off about 5 or 6 inches from one end of the rod. This will be the handle, so you can adjust it according to the size of your hand.
Use a hand saw. Be sure to keep your fingers clear of the blade.
STEP 3: Preparing the Handle
Clamp the handle onto your workbench. Drill a hole through the it longways, wide enough for your toilet tuber to fit inside snugly. Sand the ends of the handle.
STEP 4: Putting the Two Together
Insert the toilet tuber into the hole in the handle. Push it to the end.
STEP 5: Sizing the Wand
Cut the toilet tuber to the length you want your wand to be. Cut that thing off the end.
STEP 6: Stringing the Base Wire
String a wire (common) through the wand, letting some wire hang out each side. In the picture, it's white.
STEP 7: Strip! (Wires)
Strip a cm off the wires on each end.
STEP 8: Soldering to the Battery Holder
Solder the end of the white wire coming out of the handle to the battery holder. Solder another wire (hot) to the battery holder (the black one).
STEP 9: The Switches
Cut four wires with a length from the tip of the wand to where you’d like the switches attached. Strip 1 cm of one end of each wire. Solder 1 wire to each tact switch.
STEP 10: Grouping the Switches
Solder the hot wire onto the tact switch. Then bend it over to a second tact switch and solder it onto that one too. Clip off any hangings. The switches will be placed in tandem on the wand.
STEP 11: 'U'
Solder the hot wire from the battery into the two sets of switches. Arrange the switches onto the handle of the wand and pull the lead wires to the tip.
STEP 12:
Twist all the common leads from the LEDs together. Solder the twisted wires to the common wire extending from the wand. Push the excess wire back into the wand tube.
STEP 13:
Solder wires from each of the the tact switches to the hot leads on the LEDs.
STEP 14:
Twist the wires around the shaft of the wand and wrap with electrical tape. Punch holes in the tape so the tact switches extend though. Also remember to leave enough room when attaching the battery holder so you can change the battery when needed.
STEP 15:
Learn the position of the tact switches so that you illuminate the correct curse when casting your spells.
21 Comments
Hathorkiss 7 years ago
http://www.thelivingstore.co.uk/Item/rolson-flexible-led-torch-60736?gclid=Cj0KEQiA-_HDBRD2lomhoufc1JkBEiQA0TVMmnWQLBae8DKPHWC2ZMtYFkllanVcSe1utlWY5FCMXBEaAoYz8P8HAQ
JavaD1 8 years ago
nice
phillipcd 9 years ago
A great idea.
A bit hard, though.
harry potter rules 12 years ago
nodoubtman 12 years ago
Dylan Richards 12 years ago
tangerinne 12 years ago
Alexvolos1 12 years ago
http://www.e-switch.com/entity/tabid/95/entityname/category/categoryid/1/sename/tact/default.aspx
shakespeare1212 12 years ago
blinkyblinky 12 years ago
I only took pictures of the red LED because it had the highest quality. The others were kind of cheap =P
Red + Blue + Green = White
This is of course, all at maximum brightness
Mdob 12 years ago
Wasn't the movie great?
AngelInTheNight 12 years ago
