Magnetic Workshop Rings
Intro: Magnetic Workshop Rings
This Instructable is inspired by my complete inability to keep track of things, especially tiny ones. I've dropped countless nails from atop ladders and have completely lost Dremel bits, that I swear...were just there a second ago!
These simple wire rings use tiny neodymium magnets to hold on to small parts. They easily hold several nails, a couple bits or those bookshelf things that I always, always misplace. But they are not so strong that you'll be picking up all the hardware around you or pulling the iron out of your friends' blood.
Since these are intended to be worn only while working on projects, the emphasis is on speed and ease of construction over durability. Fully expect them to occasionally bend out of shape or need a new magnet now and then. If you want something stronger, a soldering gun and more complex wire wrapping techniques could be employed.
Admittedly, the crystals add no practical value, however, being in your workshop all day doesn't mean you have to be a ragamuffin : )
STEP 1: Cut and Wrap Wire
These are the supplies for all the rings. I've divided the rest of the Instructable by design type as the steps are pretty straightforward.
Materials
16 gauge copper wire
Neodymium magnets
Swarovski crystals
Jewelry glue
Foil (Design 3 only)
Tools
Vise
Round pliers
Flat Pliers
Wire cutter
Mandrel
Metal File
STEP 2: Design 1: Double S-Shape (Adjustable)
The convenient thing about this,and the next, ring design is that since they are not closed circles, they are adjustable. So it is not a problem if it turns out the wire was a little too long or short. You can also wear on any finger.
Steps
- Measure wire on mandrel and cut (For a Size 7 ring you'll need about a 4" piece of wire.)
- Use round pliers to create two loops on each end of the wire (S-shape)
- Turn both ends sideways
- Bend around mandrel to shape
- Place in vise and set in magnets and stone
STEP 3: Design 2: Two Loops (Adjustable)
This one is just an easier version of the first (and probably the most practical). You can make this in about 30 seconds, plus the amount of time for the glue to dry.
Steps
- Measure wire on mandrel and cut (For a Size 7 ring you'll need about a 3" piece of wire.)
- Use the round pliers to create one loop on each side
- Turn loops inward
- Use ring mandrel to bend into shape
- Set ring in vise and glue in magnets
STEP 4: Design 3: Large Magnet
This design if for setting a larger magnet. The one in the picture is about 3/8" in diameter.
Steps
- Measure wire on mandrel and cut (For a Size 7 ring you'll need about a 8" piece of wire)
- Keeping the wire on the mandrel, wrap both ends clockwise to form a circle* just slightly smaller than the magnet
- Leaving enough wire to create small loops, cut the ends
- Use round pliers to make a loop on each end
- Flatten wire circle if need be
- Set ring in Vise
- File down center to create as flat a surface as possible
- Cut a piece of foil the same size at the wire circle
- Glue foil to center , magnet to foil and add crystals (or additional tiny magnets) in the loops
11 Comments
Tttjande 10 years ago
What an awesome idea!!! One tip if you want to make the ring hold it's shape better, before you add the crystals put it on the mandrel and harden by hammering. Can't wait to make one for myself and other friends who craft. So tired of constantly searching the floor. :)
sdfgeoff 12 years ago
Brilliant solution too.
AlysiaMakes 12 years ago
KreaKatri 12 years ago
Great for crafty women who likes to be girly/dressed up/whatever while crafting :)
sabu.dawdy 12 years ago
mcaliber.50 12 years ago
annahowardshaw 12 years ago
Myranda_e 12 years ago
ChrysN 12 years ago
mikeasaurus 12 years ago
