Magnetic, Under-shelf Spice Rack...
Intro: Magnetic, Under-shelf Spice Rack...
Spices are an integral part of any kitchen, but, if you're like me and your kitchen is smaller than your closet, they can take up valuable shelf space. Keeping that in mind, here's a way to store your spices in an unobtrusive way that doesn't take up shelf space.
Materials:
Spice Jars (I got mine from Williams Sonoma but you can get cheaper/different ones)
Magnets (Mine are from K&J Magnetics)
Dremel or Drill
Cardboard
Pen
Measuring tape (if you're anal about measurements)
Epoxy or superglue
Materials:
Dremel or Drill
Cardboard
Pen
Epoxy or superglue
STEP 1: Preparation
Its important to make sure that your materials are in order before beginning anything. This means laying out your magnets, making sure you have enough, and measuring your space underneath your cabinet.
I laid out my magnets on my spice jars. The tops are metal (steel?) so the magnets stick, but you want to make sure that your magnets are all pointing the same direction.
I also made a quick and dirty template for drilling my holes by tracing the bottles on a piece of cardboard and stabbing it with a knife.
STEP 2: Tracing Holes and Drilling
I took the template that I made and used a felt tip pen to draw my guide holes. These don't need to be perfect, just general guides for where to place your magnets.
I used the burr setting on my Dremel in order to make short, shallow holes wide enough for the magnets and deep enough for the magnets to lay flush once they're glued.
STEP 3: EPOXY
Now is the time for you to very safely smear epoxy into the holes. I cannot overstate how important it is for you to wear hand protection. This is why I am wearing my incredible gloves that look almost exactly like my real hands.
It is also important to use epoxy in a well-ventilated space as it will eat your brain tissue and turn you into a zombie.
Smear epoxy into the holes, just enough for there to be a base. Let the epoxy set for about a minute, and then push the magnets into the epoxy in order to set them. Make sure to place the magnets into the holes such that they adhere to the magnets on the lid of the jars, if not, your magnets won't stick (they will repel, in fact!). Then, apply epoxy over the magnets in order to seal them into the holes.
Next, very carefully move the magnets underneath the top of the jar so that they are in the same position as they were previously. You need to make sure they're in the same position so that they magnetically adhere to the magnets you just glued in.
STEP 4: Enjoy.
Once the epoxy has set for all of the magnets, attach the jars back to the magnets and enjoy your new magnetic under-counter spice rack!
34 Comments
sasrf 6 years ago
- which specific K&J magnet did you use ?? (item no??)
- If the lid is iron/steel plate, would it not be better just to fix magnets only on the underside of the shelf ??
www.microbike.ie 12 years ago
antioch 9 years ago
That just wouldn't have worked out so well in the long run and it just wouldn't have been less work no matter how often you say just... =)
Garrigus 10 years ago
If you want to make the jars opaque there is a spray paint made by krylon that looks like rock..
drubinder 11 years ago
garrett.tillman 11 years ago
Magnetic paint is too weak for the jars + spices. It's better for binding things against a wall rather than suspending them.
Larger square magnets would work, as would a large piece of sheet metal (steel or the like) screwed onto or epoxied to the underside of the cabinet or shelf.
I liked the flush look and the absolute certainty that these puppies would stick to one another, which is why i counter-sank the neodymium magnets into the wood and epoxied them in.
Spice rack 13 years ago
bman114 13 years ago
HmOnGbOi 13 years ago
SydneyTripp 14 years ago
EoinCannon 14 years ago
If it's has a steel or other magnetic metal for the cap then it will stick to any magnet.
Great idea though and very neatly done.
bobsbestgirl 14 years ago
njdjs 14 years ago
I made mine just a little diffrent. I used the heavy duty magnets that you stick your tools to. I think I got them for 4 bucks each and then I used the small fancy canning jars with the designs made in the glass. I also have some baby food jars for smaller amounts of spices. I just stick the jars to the magnet. No magnets needed on the jars. It works great. I love it.
garrett.tillman 14 years ago
njdjs 14 years ago
lizardknits 14 years ago
JustinPayne 14 years ago
Spices, when exposed to light, degrade faster. I'm very surprised that most commercially available spice racks have containers that are clear. My guess is that seeing spices in their containers are very aesthetically pleasing but don't do much for the spices themselves. If you could in some way opaque the light, maybe with some patterned shelving paper or like, you'd help keep the look but extend the shelf life of the spices.
Hope that helps
GeeDeeKay 14 years ago
My suggestion is to find a bulk source for spices where you can purchase small amounts frequently. Penzey's online will sell as little as an ounce at a time. I've had great luck with their quality and freshness, and if you buy a number of different items, the cost is as good or better than supermarket prices even with shipping. Plus, it's fresh! You may have local sources for bulk spices, too, so check around.
Small quantities replenished often makes for happy spicing!
