Make Raisins With a Dehydrator
Intro: Make Raisins With a Dehydrator
Raisins are great in a variety of foods, they add just a touch of sweetness and the chewy texture is delightful. Sadly they can be expensive to buy, instead try making your own. It is easy, inexpensive and rewarding. Now you can say the oatmeal raisin cookies were made completely from scratch!
STEP 1: What You Will Need
Need:
Organic ripe grapes (any amount)
1 lemon
Large pot with boiling water (enough to cover all the grapes)
Large bowl with cold water (enough to cover all the grapes)
Dehydrator
Wire basket
STEP 2: Preparing the Grapes
Pick the ripe, undamaged grapes from the stem
Rinse well in warm water
Place in wire basket
Immerse in boiling water for 30-60 seconds to blanch
Rinse immediately in cold water
Transfer blanched grapes to bowl of cold water. Make sure water completely covers grapes. Squeeze the juice from 1/2 the lemon into water (you can use a teaspoon of citric acid but I like the subtle taste of the lemon in the finished product).
Let sit for 10 minutes, stirring occasionally.
STEP 3: Grapes Into Dehydrator
After soaking for 10 minutes remove the grapes and pat dry (or let air dry)
Arrange grapes on dehydrator trays with space around each grape (none of the grapes should be touching)
Start your dehydrator. Mine does not have temp settings so the process takes a bit longer. If yours has temp settings you can set it at 130-150 degrees F for the first hour or two then drop it down to the 100-110 range for the rest of the dehydration process.
STEP 4: Done!
After ~ 24 hours in the dehydrator and once the raisins are as raisinesque as you like, remove the trays from the dehydrator and allow to cool for about an hour.
Store in an airtight container in a cool place
Congratulations your done!
7 Comments
Tim_in_seattle 3 years ago
Overall, I’m glad I decided to make raisins, so I don’t have to eat 30 pounds of grapes all at once
Talktina 1 year ago
Everlong 12 years ago
stacyah 12 years ago
vic.stitches 12 years ago
scoochmaroo 12 years ago
mikeasaurus 12 years ago
