Make a Boat Powered by Fire.
Intro: Make a Boat Powered by Fire.
There are many ways to power a boat - propellers, aquajets, sails, powerful fans, turbo-jets, rockets, and pulse-jets.
There are few ways, though, as gentle and serene as the warmth of a candle.
STEP 1: What You Need.
Fire-boats need two important properties - to be light, and non-flammable.
My Clubbers used foil pie-tins as the hulls of the boats, kitchen foil as the sails and tea-lights to provide the heat.
We have, in the past, had success with normal-sized candles trimmed to only half an inch in height, or small clusters of birthday candles.
STEP 2: Construction
Making a fire boat requires no specialised tools. In fact, it requires no tools at all.
A certain amount of intuition is also desirable.
Tear a piece of the foil to a suitable size, and fix it to the side of the pie-tin by scrunching the edge of the foil along the lip of the tray.
Curve the sail over the top of the boat. If it droops too far, add a crease or curve along the middle of the sail to ~~stop it drooping~~ add structural integrity.
Stand the candle in the boat, and you're ready to go.
The photos in this step are of the fire boats made by my Science-clubbers, before they took to the water. Some required tweaking, but they all worked to some degree.
STEP 3: The Circular Fire Boat.
If the sail of a fire boat is not level, it will tend to spin.
This effect can be used on purpose as well - setting up two candles and sails facing in opposite directions on a circular metal lid created a boat that spun on the spot.
The clubbers had the idea that the idea could be used to make decorations which floated and spun in garden ponds or pools during a barbecue or garden party - the shiny foil sails would cast changing reflections around as the boats spun.
STEP 4: Float Your Boat.
To see the fire boats working to their full potential, they need calm. Calm air and calm water.
We poured shallow pools of water into plastic trays and left them to settle. We also closed all the windows and doors to prevent draughts, and walked slowly so that the breeze of our passing wouldn't disturb the boats.
Place the boat at one end of the tray and light the candle.
As the candle burns, it heats the air around it. As you are probably aware, warm air rises. This is a convection current.
When the rising air hits the sail, it is deflected from its vertical path, which exerts a small, but real, force on the sail. Since the sail is fixed to the boat, the boat moves.
This video shows a couple of the boats my clubbers made:
72 Comments
AH Electronics 10 years ago
Kiteman 10 years ago
lilchumy 11 years ago
Kiteman 11 years ago
makerboy112 13 years ago
Kiteman 13 years ago
Science+imagination=Instructables.
simplebotics 12 years ago
ParacordJedi 12 years ago
TheRacker 12 years ago
80$man 12 years ago
Firstly, Newtonian mechanics (physics) coupled with fluid buoyancy effects (Archimedes) is causing the propultion. Convective heat transfer only causes fluid buoyancy (of the air) which has an action/reaction with the sail.
Secondly, could you consider rather funnelling the hot air into a converging tube that draws air under the boat allows the hot air to push against the water? This should provide a serious increase in propulsion! I have seen such a tube made from a hollow kettle element, but a crimped copper tube should suffice. Any thoughts on such improvements?
Kiteman 12 years ago
Jessierocks 12 years ago
ilpug 12 years ago
knektek 14 years ago
Kiteman 14 years ago
Frindledon3 14 years ago
panzer 15 years ago
i will post my idea soooon, cuz u gave me the best idea ever!!!!! and i have everything that is needed, cause its so simple, YES!!!!!! ha ha, thanks
greatttt instructable!
Kiteman 15 years ago
Drop me a PM when you post it...
