Make a Microbial Fuel Cell (MFC) - Part III
Intro: Make a Microbial Fuel Cell (MFC) - Part III
This 5 gallon single chamber microbial fuel cell uses inexpensive conductive cloth to provide a silver catalyst and a styrofoam permeable membrane.
Operation of a single chamber MFC is complicated by oxygen poisoning resulting from the conflicting requirements of the anaerobic population and the cathode requirement for dissolved O2. This design attempts to limit oxygen poisoning by using a brush type carbon electrode combined conventional carbon paper to provide a gas barrier without limiting free flow of the microbial medium.
The use of styrofoam as the permeable membrane is novel as far as I can tell.
Conductive cloth is used to provide an inexpensive silver catalyst to promote oxidation at the cathode. We use silver plated conductive cloth from lesseremf but any silver plated material should do. The use of silver as a catalyst is based on the research done for the air cathode in an aluminum air battery and is experimental in an MFC.
As you can see from the picture I got about 90 mV across the open circuit after charging and assembling the cell. The extraction of power from an MFC scales directly in proportion to two things, population density and surface area of the electrode surface at the cathode and anode.
Power will continue to rise as the population density increases.
STEP 1: Bill of Materials
This is a simple bill of materials and assembly. Because we are building a single chamber MFC we won't need to create a salt bridge or anything like that.
1 5 gallon plastic pail with lid - I got my mine at Home Depot on sale for $2.97 plus the lid
8 in styrofoam disc - Cut out of packing material or I'm using one I got at Michael's
Use loose styrofoam if you can get it. You want air to pass easily through
Anaerobic Microbial Culture - I'm using "Microbe Lift" brand Septic Tank and Cesspool Treatment
Yeast should also work
1 Package of large aquarium charcoal filter pads. I'm using Fluval brand 4 PLUS filters
Silver coated conductive cloth - http://www.lessemf.com/fabric.html I'm using the "Stretchy silver coated sheer nylon weave". This is used as a catalyst to facilitate oxyidation at the air cathode. It also as the electron collection grid.
A couple of wire leads with clips or some way to attach them to the carbon pads.
Two sheets of carbon paper. This is used to get good mechanical connectivity between the pads.
STEP 2: Create the Styrofoam Cathode
The styrofoam cathode which sits at the top of the MFC chamber is a gateway that admits air and vents biogas resulting from the microbe action.
As you can see in the picture it is a sandwich. The bottom layer is styrofoam, next is a layer of conductive cloth, then two carbon pads laid side by side. This is followed by another layer of conductive cloth, then the carbon paper. As you can see in the picture the carbon paper is placed with the shiny side facing the conductive cloth.
The electrode assembly is attached to the styrofoam by means of 4 toothpicks and a strip of clear plastic tape.
STEP 3: Prepare the Microbial Chamber
Now take the lid and carefully cut out the inner circle. This will be an almost perfect fit for the styrofoam disk.
Next prepare the anode assembly on the bottom of the pail ( see picture ). This is done by laying down an 8x5 inch piece of carbon paper, followed by a 8x5 inch piece of conductive cloth then the two remaining pads from aquarium filter.
This assembly is buoyant and tends to float when the solution is added. I found it necessary to attach this assembly to the bottom of the pail with clear plastic tape. I think super glue and/or a slightly different assembly might be easier.
Okay now we're ready to charge this puppy up and see what happens...
STEP 4: Assembling and Operating the MFC
Okay Tesla let's turns microbes into electrons....
Put in the rest of your shredded paper so that the anode is liberally covered.
I went down to Big Lots and picked up a couple of 3L bottles of inexpensive soda to use as microbial media but almost anything can be used. Make yourself a nice 5% sugar water solution or use a mild vinegar solution.
I chose these because I wanted the 3L bottles for the next generation of my Wind Turbine and thought it would make a good sugar based medium. I certainly wasn't going to drink the stuff. Also the acid in the soda will help to break down the paper.
After you've added the soda place the bucket out in the afternoon sun for a couple of hours to vent the gas. The fill the pail the rest of the way with water. The styrofoam will float on the water and press against the lid to obtain a seal (more or less).
Attach the second lead to the carbon electrode on the styrofoam. Float the styrofoam ( carbon side down ) in the water and the two leads around it through the hole in the lid.
Add 1/4 cup or so of Microbe Lift to charge the MFC and then press the lid down firmly.
Simply attach a 220 ohm resistor across the leads and begin measuring voltage.
33 Comments
egbertfitzwilly 14 years ago
jdgable09 4 months ago
zaschita1 8 years ago
Could you tell me how to increase current for at least domestic use? After all, the current strength is very low. It is a question of scaling MFC.
SHOE0007 8 years ago
A better way is to make copper electrodes plated with cobalt from cobalt (II) chloride for the negative and the positive would be platinum electrodes. The electrolysis of cobalt chloride would create a plating of cobalt metal over the copper strippling. Since fumes of cobalt (MAY) be released this must be done outside with a gas mask. Plenty of ventilation is required too and this is because some chlorine is produced. The cobalt will react with air to form cobalt oxide which would eventually form cobalt plated (cobalt hydroxide).
For agar containing 17.5% hydrogen peroxide gels this worked for 6 hours.
6 pm = 10 mA.
7 pm = 9 mA.
8 pm = 8 mA.
9 pm = 7 mA.
10 pm = 6 mA.
11 pm = 5 mA.
The problem is the fairly quick release of hydrogen peroxide and the copper and stainless steel electrodes. Perhaps using platnium metal electrodes instead of copper and stainless steel may work since they will not react with anything.
I am thinking of adding 1 mole Potassium ferrocyanide trihydrate in knox gelatin. Bacteria will slowly break down the potassium ferrocyanide trihydrate and react with gels of H202. Gels will contain knox gel and 20 ml water. Once the temperature reaches 60 degrees C add 20 ml of 35% H202. I will see if this work or not?!!
the voltages were near 810 mV or so. The total power when 3.5% hydrogen peroxide was added was 21 mW.
Micheal hook 9 years ago
First time I come to hear about 5 gallon single chamber microbial fuel cell. It is good for users knowledge. It is scientifically as well as logically approved and appreciable. It is just for experimental. Fuel mileage is very important and essential for an engine, we can say it is the life of that engine. Maximize your fuel efficiency-
http://vimeo.com/114647629
Burgess_Shale 10 years ago
Dr Qui 13 years ago
Is it possible to power any electronics as is or would you need bigger or more of them?
Is there a large scale application?
egbertfitzwilly 13 years ago
goatboy825 11 years ago
What about the graphite fabric and chicken wire one they are using in Africa?
It seems to me that the other side of this power generation is a DIY storage battery or bank of DIY capacitors...
Everyone is focused on lightweight protability for cars. Like you I am thinking of homes that don't move and all the recycled stuff (like buckets, styrofoam, beer cans and milk jugs)
How about a jumbo low-tech battery or capacitor to store the fuel cell power in?
Dr Qui 13 years ago
Does the yeast culture feeding on the paper and sugar from the soda make an electrolyte type substance that powers the cell?
Would it be more efficient at the equator than saw Canada or Ireland?
You are indeed a scientist, you work is pure science, much cooler than anything they ever showed us at school.
The best science and technology comes from men in sheds who often make groundbreaking discoveries.
CoolKoon 14 years ago
I believe the 5 gallon pail ( and larger tanks ) are best suited for a single cell approach where chamber "seperation" into aerobic and anaerobic portions is controlled primarily by depth.
How did this two chamber model of yours perform then?
I suspect that if a salt bridge were connected to the cabbage bucket a charge could be generated and multiple cells could be wired in series. Grandma would be proud....
A salt bridge is usually used to facilitate ion exchange between two separate electrolytes. You see the charge carriers are not the water constituents but the ions dissolved in it, otherwise some distilled water could work as an electrolyte too (without prior charging, of course). I'd say that the charge carriers (ions) give up their electrons by merging with the materials of the electrodes itself. Now I'm sure things are a bit different when microbes are involved, but I don't know much about the mechanics involved. So the question remains: if the microbes can survive only in an oxygen-free environment, what's the O2 there for?
As for the sour cabbage electricity thing I thought about that too. Unfortunately my grandma passed away about a year ago as the result of a final stroke. She never recovered fully even from their second one though (wasn't the same person anymore), but have I tried that before (attaching electrodes to sour cabbage and testing it with my multimeter) she would've surely been convinced that I've gone crazy and banned me from the basement (by hiding the key) :P No sour cabbage has been for a long time (probably for practical reasons as well, because it wouldn't be eaten I guess) so I don't think I could try it out (especially because none of my parents like my experiments either :S). Still, it's a really interesting idea that's worth a try.....
