Make a Usb Laser Air Purifier Lamp
Intro: Make a Usb Laser Air Purifier Lamp
Laser can refresh your air by kill the bad bacteria and fungus in the air.You can make a cool lamp too. All with the usb power.
STEP 1: Cut Pc Blade
cut all the blade on a pc fan,drill 4 hole on a moni dv disk and glued 4 laser
STEP 2: Place Plasric Bottle on the Machine
tape with black tape and let 4 hole for the air extraction,place 4 screw for making the leg of the machine
STEP 3: Plug a Usb Cable
plug a switch and after take a usb cable and take the red and black wire for powering the machine
STEP 4: Now Just to Put the Switch on and See the Beautiful Light
cool
50 Comments
SHOE0007 8 months ago
If u had distillation tubes you may If u are extremely careful is rap the tube around the laser especially the 1 to 2 W lasers.
Ensuring no water leaks it could be water cooled. Special thick rubber tubes and an aquarium pump may help with proper cooling especially if run Long term.
Maybe a 405 nm, or 445 nm 1 to 2 Watt laser module Quite expensive may kill some types of bacteria or yeast.
What u need to do extremely carefully is air cool high powered lasers 1 to 2 watt with prisms in a enclosed space.
You need to carefully grow certain bacteria (Milk bacteria), Maybe friendly E coli (Ecoli A and B strains) and grow them and expose the bacteria to the high powered laser with prisms and proper safety goggles.
Usually uv at 254 nm is used but those lasers are extremely expensive 4 triple frequency laser 7 to 20 grand.
AlexR9 9 years ago
buy UV-C BULB and place it in the center
http://news.discovery.com/tech/robotics/ebola-zapp...
casper.707 15 years ago
GrfxGawd 11 years ago
Redgerr 13 years ago
P.D.T.Burdett 15 years ago
calinux 13 years ago
Callum Snowden 13 years ago
TheMaker888 13 years ago
msm_bound 14 years ago
i have two questions :
1- how did u make the laser work ??? i mean how and where to connect it
2- where do i get this laser parts and for how much ??
please i am in the dead line for doing this project so i need ur help as soon as u can
hivoltage 14 years ago
IlluminatedAntichrist 16 years ago
Phazonx 16 years ago
greenbean 14 years ago
Uthman 16 years ago
SecondSun 16 years ago
junits15 14 years ago
lagenger 16 years ago
