Making a Bola
Intro: Making a Bola
The bola (Spanish for ball) is a throwing weapon that generally consists of three weights on the end of three ropes (that's a good one on one correspondence example for all you people taking pre-algebra). The purpose of the bola is designed to rap around the animals legs and make them trip and fall, this weapon is most famous in Argentina. To make the bola wrap around the animals legs better, one of the weights is smaller and/or lighter.
Many of you have probable seen the move 'Kangaroo Jack' were they try to catch the kangaroo using bolas. If you're like me you would have been amazed and thought about how you could make one.
In this instructable, I will show you how to make a monkey's fist bola.
STEP 1: Tying the Knot
Due to the marriage protection act you can only tie knots with the opposite sex, but monkeys fists (except in a few very rare cases) naturally have no gender, so everything works out......
Now that your all hiped up saying " I'm gona make a bola!" I'll have to break it to you, this bola requires a bit of skill in knot tying. This is because monkey's fist bolas, well.....require monkey's fists!
To make the monkey's fists you need rope, I recommend using about 3/8" rope, and having about 25 feet for this project. One of the annoying things that can happen when you are making a monkey's fist, is when you are about to finish, when you run out of rope. When you tighten the monkey's fist, it goes to the end of the rope, so it's not a problem if the untightened monkey's fist is not on the tip of the rope. I used sisal rope because I like the natural look and feel. You will also need three weights, If you want to be primitive, you can use two golf ball sized stones, and one smaller and/or lighter weight stone. I live in Florida, the land with no rocks, so I used golf balls. I used two golf balls of the same weight, and one lighter weight, practice golf ball.
I will separate the steps in making a monkey's fist into different step sections for better clarity.
1.1 Wrap the rope around your fingers (see picture) I am right handed, so I am wrapping with my right hand.
STEP 2: Tying the Knots 1.2
1.2 After you wrapped the rope so that there are five (Please ignore that the second picture has only four rings, I'm an idiot like that sometimes!) "rings" of rope, wrap once around your ring finger.
STEP 3: Tying the Knot 1.3
1.3 After you have wrapped the rope around your ring finger, wrap the rope around the previous wraps (see pictures) repeat this until you have five rings there also. But wait! When you get two or three wraps, insert the weight.
STEP 4: Tying the Knot 1.4
1.4 After you insert the weight, continue to wrap the rope like step 1.3 described. (Admire mushroom)
STEP 5: Tying the Knot 1.5
1.5 After you have wrapped the rope like the previous steps described start wrapping in the third direction (see pictures). The third direction should be around the ball in the direction that you haven't wrapped around before, you might want to think of the three directions as x, y, and z.
STEP 6: Tying the Knot 1.6
1.6 After you have wrapped in the third direction the right number of times, tuck the tip of the rope under the other section that runs over the current section, this is the section that you would wrap under if you were going to wrap more. (see picture)
STEP 7: Tying the Knot 1.7
1.7 Now that you have tucked the tip under the perpendicular section, press down on it with you thumb. Then begin tightening. To tighten, pull on the loose areas and thread through the knot, this should form a loop.
STEP 8: Tying the Knot 1.8
1.10 Now after you have made the monkey's fist cut it to the right length. I figured that different sized people would need different sized bola ropes, so I cut the rope (with the monkey's fist on it) to be from my hand to the middle of my chest, after I tied all of the ropes together, this shortened it to my shoulder, this seamed a reasonable length.
STEP 9: Tying the Knot 1.9
1.11 Make two more bola weights like the one you just made.
Now that your hands are nice and tired, lets move on to the next step.
STEP 10: Tying the Weights Together
Now for the easiest step. Tie all of the weights together by their ropes. Do this by using an overhand knot. Make sure it's tight, or the bola weights might separate from each other and hurt your friends when you showing of you mad skills.
STEP 11: Using the Bola
Now that you have an awesome bola it's time to use it. Unlike in the movie "Kangaroo Jack" where as far as I can remember they held it by the the central knot. With this bola you hold it by one of the monkeys fists (I like to hold it by the lightweight fist). Then swing it over your head and let go at the right time during the rotation to hit your target. It takes a bit of practice but after a while (I didn't say a short one) you might get to be as good as the Argentinians (that's meant to be optimistic).
Also, the weights can be made from tennis balls, then you can throw them at you friends.
Good luck! I am a beginner so suggestions are welcome.
43 Comments
HelenaTroy 6 years ago
ps I meant "after tying the three arms together", not "after tying the monkeys fists". Sorry.
I have a couple of questions:
1: how much did your lighter ball weigh? I don't play golf, so how much did a proper ball weigh, please? if I know both weights I can work out what ratio to use.
2: how long are the bold arms after tying? Is there any ratio between this length and the length of one's arm?
Thanks!
calvin.ritchey 9 years ago
These work really well. I made one as a child of maybe 8 or 10 after reading a book on Argentina. Made my younger brother run across the yard, and took him down like a redwood tree! He wouldn't let me try it again, unfortunately.
Shiraz 14 years ago
steven.owensby.50 9 years ago
My Grandfather used/made them in Portugal, Shiraz. Could that be where he got his incorrect info from? He used it from everything from Working Cattle, to Hunting, to deal with obstinate kids.... lol
rimar2000 12 years ago
mikaelthemycologist 12 years ago
smorrone 14 years ago
dnash2 10 years ago
dspencer9 11 years ago
ilpug 12 years ago
I made something quite like this a while ago, and it was fun, until it went wild and dented my fence. These things can fly a bit oddly until you get the hang of it. I recommend spinning it only once prior to throwing, not multiple times. This makes it more accurate, and the extra spinning grants no extra power.
finfan7 15 years ago
wal11 12 years ago
finfan7 12 years ago
wal11 12 years ago
spylock 12 years ago
eulaliaaaa! 12 years ago
Oberoten 13 years ago
Way to go.
Makersauce 14 years ago
